1st gen dash illumination write-up
Old Aug 26, 2009 | 02:33 PM
AZkid's Avatar
okay, first things first, i did NOT order any special bulbs or anything.
you'll see what i did further down. I HAVE THE DLX CLUSTER.
here's the steps,
1.Remove top dash cap. Two screw underneath, two above displays, one on side, (on mine atleast)
2.Place dash cap somewhere safe, ex: workbench, or elsewhere. I like to fold down my back seats and set it there.
3.Remove cluster, three wires and one speedometere cable. You got one wire on your right side at a 45 degree angle, one in the middle that is horizontal, and the one on the left is at a 45 degree angle too. Speedometer cable has a clip you pull up and pull off at the same time.
4.So you got the cluster out now, make sure you have somewhere to put it when you work on it, workbench, countertop, coffee table, or dinner stand.
5.Unscrew the top metal pieces, screws are located on the back.
6.You DON'T need to pull off the clear piece. There is no need to, well unless you repaint like i did.
7.Unclip the plastic pieces, I believe there is fourteen total, with like seven on bottom and seven on top. Be gentle.
8.I popped out the green piecs for the blinkers to show the illumination.
9.Clip the two plastic pieces back together. DO NOT TURN THE TWO LITTLE SCREW ON YOUR SPEEDOMETER, YOU CANNOT ROLL YOUR OD OVER. THE SCREWS WILL MESS UP YOUR SPEEDOMETER.
10.The bulbs are on the back, They are a quarter turn on, and a quarter turn off. very simple.
11.I painted mine, this is wehre you would put in the ones you bought, im just cheap Skip to step XXXXX if you bought some
12.I chose a couple different colors and paints, I need to see which ones work, I'll post up night time pics tonight or tomorrow.
13.After painting screw them in where they belong. REMEMBER WHERE ALL OF THE CLEAR ONES AND COLORED ONES SHOULD BE. Colored should be in the middle four, standard non colors on the left and right, no need to paint them cause it wont make a difference.
14.Reassemble. The only thing that Ihad a little trouble with was the speedometer cable and the wires.
Picture time, pictures are in the order that i did them.
Nght time pictures will be taken tonight.
I put the orange ones in for the blinkers to tease you guys till tonight or tomorrow when i get the pictures
Enjoy
i'll do one on the inclinometer once Ifigure out where the plugs plug into.
Old Aug 26, 2009 | 02:36 PM
iamsuperbleeder's Avatar
I'm not sure if I should call you original, or just plane CHEAP
lol, definately never seen it done like that before
good job man! would like to see some night pictures
I'm curious to see how the paint is going to hold up to the heat of the lights that stay on for long periods of time, like the running lights and what-not
one question though... why the black bulbs?
Old Aug 26, 2009 | 02:41 PM
AZkid's Avatar
better question, why not?
i figured i was testing it out, might as well see what does and doesnt work, the orange turned red so the black will be like a grey.
and i ran my blinker for a good two minutes and took the bulb out and checked it and it was fine.
Old Aug 26, 2009 | 02:47 PM
algranger's Avatar
You know when you add color to a bulb, all light is filtered out except that of the color your bulb is. There is no "black" broadcasting from your bulbs so all you're really doing is dimming them down.
Otherwise looks good i like your idea
Old Aug 26, 2009 | 02:51 PM
algranger's Avatar
Oh and i dont think the heat will be an issue, they dont get that hot.
If it is an issue, there is a paint called "Engine Enamel" which will withstand 500* temps (even air cooled engines want to look perty now and again)
I've also noticed it's very thin, takes many coats to get a nice solid finish. The transperency would probably work pretty well for a bulb
Old Aug 26, 2009 | 02:56 PM
AZkid's Avatar
i still think they are gonna turn out fine.
i orignally wanted a grey backlight
but i like the red,
matches all my other gizmos.
Old Aug 26, 2009 | 03:03 PM
RMA's Avatar
RMA
You know I just put a lexus cluster in my 1988 4runner and have the sr5 cluster I will be selling , pm me if your interested. If Not Its all Good .
Old Aug 26, 2009 | 03:04 PM
AZkid's Avatar
pm'd
Old Aug 26, 2009 | 03:05 PM
a Lexus cluster?
where is this writeup?
Old Aug 26, 2009 | 03:06 PM
AZkid's Avatar
in his sig whole write up
Old Aug 26, 2009 | 03:08 PM
yeah I just found it at the end of that thread, lol, I was just being lazy
Old Aug 26, 2009 | 03:17 PM
RMA's Avatar
RMA
a Lexus cluster?
Yea , Ive been Hidding in a little corner here hoping all went well with this swap.
Old Aug 27, 2009 | 12:24 PM
AZkid's Avatar
I didn't have time to test the others, but I got those two done, I like the red, I want to try blue.
Old Aug 27, 2009 | 01:01 PM
RMA's Avatar
RMA
that red does look cool ..
Old Aug 27, 2009 | 02:02 PM
AZkid's Avatar
it matches the brake light and all the otehr red ones too :p
ghostmoney
Aug 6, 2015 08:40 AM
vanion2
Jul 29, 2015 06:17 PM
TDonkey
Jul 26, 2015 10:14 AM
noahstancik
Jul 17, 2015 05:38 PM
