how do I compression test?
Old Aug 31, 2009 | 04:52 PM
rascholla's Avatar
I know the basics. I need details. Does anyone know the quickest way to get it done? Let me know.
94 4runner 3vze v6
Old Aug 31, 2009 | 05:00 PM
abecedarian's Avatar
Get a compression tester with the thread pitch, etc. you need.
Pull all spark plugs.
Pull the EFI fuse or otherwise disable the fuel pump.
Pull the primary coil wire (center terminal on the coil).
Prop the throttle plate fully open.
Install the tester in to #1 spark plug hole.
Crank the engine at least 2 seconds, maybe up to 5, until you get the peak reading on the gauge.
Record that number.
Reset the gauge.
Repeat for the remaining cylinders.
For any cylinder not within 5-10% of the others, squirt some engine oil in to the spark plug hole, rotate the crankshaft a few turns, install the gauge in the spark plug hole and re-test. Record that number as a "wet" test for that cylinder.
Old Aug 31, 2009 | 05:02 PM
rascholla's Avatar
can I just pull one sparkplug?
Old Aug 31, 2009 | 05:07 PM
nope. can't do a compression test on one cylinder if plugs are installed in the others, or if the throttle is not held fully open.
You want the engine to spin as fast as possible and let as much air in to the engine as possible.
Old Aug 31, 2009 | 05:08 PM
but you can do a leak down test....
Old Aug 31, 2009 | 05:09 PM
codyota87's Avatar
if u only want one cylinders compression yes. but if you want them all pull the all!
Old Aug 31, 2009 | 05:12 PM
rascholla's Avatar
ok got it. this is just what I wanted to read thanks
bugs1961's Avatar
If you want to get useful information do what Abe says.
Old Aug 31, 2009 | 05:17 PM
spark plugs left in cylinders will cause the engine to slow down as the crank spins and the cylinders with plugs left in them build their own compression.
not exactly what you want if you're checking how much air can be sucked in and compressed in any particular cylinder, right?
3-5 cylinders fighting against the one cylinder you want to measure. not fair, is it?
eggens
Oct 27, 2015 03:14 PM
_Nicco_
Sep 21, 2015 03:06 PM
Yont283
Sep 20, 2015 10:56 PM
Yont283
Sep 12, 2015 10:03 AM
Boomer8404
Sep 10, 2015 09:01 AM
