- Rancho Add-A-Leafs
- my 86 surf/4runner!
- Transmission solenoids locations A340h
- my friends pick up
- What is this for? 3.0 question?
- Air Box and pollution equip
- 87 Runner Engine code 11 & 12
- Marlin Crawler Shifter bushing?
- Diff carier bearing support came loose.
- Diff/Tranny Drain Plug Size?
- Will this hood fit?
- hey regular cab people - A Q 4 U
- chugging at 1500-2000 RPMS???
- Fixing Clear Coat on Hood
- Gaping a spark plug..1994 SR5 V6 4Runner
- 1st Gen Roll Bar Removal
- 3vze timing maximum advance for power
- starter wire question
- What should I get off a '93 for '86 4Runner
- backward headgasket? how do I know?
- Looking for clear front turn signals and corners for a 1st gen
- 2nd gen. engine swap
- A340H compatability?
- Another Clutch Question
- no rear brakes?
- Unique Mesh Grill
- 2nd gen wiring issue>
- Toyota perf. parts in Arizona.
- Aussie locker in snow/ice conditions
- some slight mechanical question.. HELP!
- climate control light
- Procomp rear coil springs
- 2wd lifts and prerunners
- Do these pistons look ok? PICS INSIDE
- Summers officially over
- ujoint breaking??!?!?
- Bushwackers on pickup?
- new shocks and hooks!!! 88 runner lookie
- Arb
- oil pickup tube diameter?
- Last stages of engine build
- 2wd engine harness same as 4wd engine harness?
- SAS kit pics
- IFS axle shaft breaking before CVs
- Post Pics Of What You Did This Weekend
- where to install full size ARB Compressor in 2nd gen?
- Small coolant hose at back of motor?
- 302 swap is about to go down!
- will fj cruiser wheels work on my truck?
- Which new paint scheme? Votes are welcome!
- 4wd gear question
- Safari Rack with Hi-Lift Mount
- Diesel gearing
- I guess my old '93 4Runner is sort of "rare"
- Where does this plug go?
- misc 4 runner questions
- loose oil dipstick...
- Shocks and rear springs for 87 Extra cab
- 33inch tires, 5.29 too much?
- Update to noisy clutch issue.
- What do these three lights mean (Brake/Battery/AT Oil)
- What is still grease splatter? U joint?
- any body have tires???
- Marlin front bumper with 3 inch body lift?
- gearing
- Where can I get a front hitch reciever?
- Just another one of those...
- Master Cylinder Differences?
- leaf spring swap
- Running board bolts stuck!!!
- rough running engine in idle and especially in gear any help appreciated
- Got myself a 4runner
- Flashing Overdrive Light??
- First Post
- Loud tapping from the fuel rail
- Center Support Bearing Help please
- power steering gone
- Base Coat Clear coat Painting 101
- 88 1st gen intermittant miss.
- Stolen 89 4Runner near Olympia, WA
- 2wd lift?
- 4Runner starts but dies after a few seconds
- T-case compatibilty
- Mileage Boosters
- Stock IFS with all four in the air.
- where do I buy paint?
- 3vze Head gasket recommendations?
- 31/11.5-15 Ltb
- Smokin'...
- 1991 Pickup help
- Went wheelin a couple days ago *vids*
- Manual Hubs Lube and Endorsement
- cheapest place to buy a lockright
- 80/100W 12V Hella H4 bulbs on stock wires?
- Need a Feul tank Filler and A Gas Tank
- oem steering stabilizer won't come off...
- A/C question
- Who covered up their rust with flares??
- chugs when gas is LIGHTLY applied
- fuel guage empty light
- Runner's Fixed
- What gears do I have, PLEASE HELP???
- 4.10 vs. 4.30? Any difference?
- how do I set adjustment on torsion bars?
- 1988 4 runner that just wont start
- 22RE Troubles
- Fuel usage
- Fixed rough idle on 22re!
- Need Help something wrong with 94 pickup
- I dont change my oil...good or bad thing?
- Timing chain broke! 22r and 22re heads the same?
- temg guage spike = blood pressure spike
- Not getting enough fuel?????HELP????
- Bolt-in pickup bed for 4Runners?
- PCV Valve and Carb Gasket
- Hey, New to yotatech + silly questions!
- Painting truck a different color....
- Finally Lockers
- I Got Hit By A Tractor-trailer And Survived!!!!!!!!!!
- My first 4runner and first post here!
- loud engine
- Popping out of 4 low
- Installing lift need some info.
- simple questions/specs 3.0
- Help Its Too Hot In Here!!
- 89 4runner fuel in intake manifold
- 88 pickup overheating at high PRM
- what year frame do i have
- 88 toyota p/u lift hight problem with superlift 4" and downey bars
- worth keeping the "old" deluxe cluster?
- jeep seats in a pickup
- 92 4runner rear lower control arm mount broke!
- High Revving when shifting
- got a new rig
- Latch for back window
- Hell is going to freeze over!!!!!
- Low idle and lope problem.
- im going to be honest....
- Who else has made it worse by trying to adjust their valves? (22re)
- 3vze to Chevy 4.3L Swap
- Snorkel help...Buick V6 3800/86 pickup
- Finally some action shots!
- Anyone run these?
- Old Man Emu Coils, Torsion Bars and Air Bags
- 95 4Runner Exhaust Bracket Question
- ARB Bumper
- replacing idler arm
- 3vze towing please HELP!!!!!
- 2nd Gen shifter knob thread partten??
- Sound setups
- Having Issues!?!
- holy seized up u-joint
- Getting muddy
- rear block vs. shackle
- Radiator Fix Thoughts
- 4wd switch questions
- weird idle, bad throttle response: TIMING issue?
- Is a truetrac in the front worth it?
- MONROE monromatic VS. Rancho 5k Shocks
- 32x11.50 vs 31x10.50 vs 33x10.50
- Should I change TRANNY FLUID?
- voltage between terminals is over 17 volts...
- Drive shaft skid?
- Removable Hinge?
- Tune up replacement, repair items.
- Cooling system gurus! Overcooling issue.
- Timing Issues?
- Check out this awsome video I found!!!! Must see
- peltier cold air intake?
- what temperature thermostat for 22re: 180 or 195
- 1st gen Side Grilles/emblems loose
- I have a guy trying to sell me a 1st gen runner
- Pictures Of My Beautiful Truck
- Daughter's new 95 4runner
- No spark on my work truck.. URGENT PLEASE!
- Bad Transmission I've Got Questions
- Sonoran Steel IFS Truss installed today
- 90 yota
- So I layed some tape down to get ideas....
- sr5 cluster installed..got some problems.
- tube doors and bumpers
- i need your opinions!!!!! 88 runner lift
- 3.0 hesitation and violent jurking
- legal odometer ajustment to new cluster
- timing chain wore through cover
- 95 toyota 4runner engine/tranny swap questions
- Using Overdrive to downshift (automatic)
- Starting A Project
- Can seafoam damage my trucks 22re?
- New extended Brake lines by Trail Gear.
- anybody tried the spindal lubricator for ifs
- Head bolt size
- 87 sr5 ? what should i offer
- Front End Question???Advice????
- gauge
- 22re Engine Troubles
- Forum Approved Bilstein Heavy Duty
- How to test knock sensor
- Afternoon Project: IFS truss
- GOT MY 31's!!!!!
- Newbie Pics: Just washed 93 Ext-cab 22re
- power stearing fluid leak
- seafoam to synthetic on my 3.0
- Rear Shock Bolt size/pitch - 86 pickup
- tube doors
- gas tank size
- pump not turning on?
- vz + E85?
- Need Help with Sliders on my RIG....
- HELP, What's wrong with my truck
- Good Price for parts??? More available!
- MY new toy
- Looking for Split Bench
- writeup: '89-'94 heater core replacement
- MSD 6AL for 93 4Runner
- Looking to buy a 1994 taco...
- Ideas for easy on easy off tops
- 1990 t4r 350 small block FOR SALE
- Flowmaster Love
- scary underside is this bad??
- Motor Oil
- rear plate bumper options for a pickup
- Help with spark plugs
- Transmission question?
- 4runner catback system interest?
- How to replace a nut a front tire??? help
- Broken Sliders
- changing transfer oil question.. help please...
- Performance Accesories Eat Your Heart Out! Pictures Inside
- ome steering stabilizer
- somebody stop me! i've gone paint crazy
- Which part is more critical?
- Leaking Water pump...
- Has anyone painted their 4Runner top??
- how do you repair cracks in the dash?
- Lift for 95 yota truck
- Superwinch???
- 95 4runner air-box removal an intake upgrade
- Valve adjustment bolts tight
- 1987 4runner turbo auto shifter.
- 87 4Runner CB Antenna Install (Pics)
- question about AFM...
- Dont Drill Your Air Box!!
- ok its about tires....
- exhaust and 02 sensor question
- 89 truck jerks in when taking off in foward gears
- Looking for a good shop in Philly area
- V6 radiator into 86 pickup?
- Help: 1st gen Runner Seat slider problem!!!!
