4.10 vs. 4.30? Any difference?
Old Sep 12, 2007 | 05:53 PM
Adawg_08's Avatar
I can get some 4.30's cheap. Will I tell much difference? I got an 4 banger 5 speed? 31's.
Old Sep 12, 2007 | 06:13 PM
toy283's Avatar
If it were me and the price was cheap, I would go for it. But, I would be setting the gears myself. IF you need to have someone else do the install and you cannot find a smokin' deal there too, I'd pass.
Old Sep 12, 2007 | 06:28 PM
hodgepodge79's Avatar
If you are only getting the ring and pinion gears, and plan to take it somewhere for the install, probably not worth it. If you are getting fully built up differentials, sure. I went from 4.10's to 4.30's when I found a e-locker rear third at a wreck yard with 4.30 gears. Two cars down was another 4runner with a 4.30 front. I got both for $300.
I definately noticed a difference off the line and in second gear (running 30-inchers), but nothing significant beyond that.
Old Sep 12, 2007 | 08:53 PM
longhungsilver's Avatar
I fully agree
Old Sep 12, 2007 | 09:37 PM
Albuquerque Jim's Avatar
The difference is when you blow a R&P you have to either find another used set or buy from Toyota. I blew 3 sets in the last year...
Old Sep 12, 2007 | 09:43 PM
tc's Avatar
tc
I went from 4.56 and 4.88 (1 step different, just like 4.10 to 4.30) and it's the best money I've ever spent - definitely noticeable!
Old Sep 13, 2007 | 05:15 AM
d0ubledown's Avatar
make sure your front diff uses 4.30's as well. if its early ifs..i dont think they use 4.30's or are available from the aftermarket. taco/3rd gen runners use a reverse rotation front 4.30 while pre taco uses a standard rotation front R&P...
Old Sep 13, 2007 | 10:53 AM
Adawg_08's Avatar
I was getting the whole truck. the frame is rotted out pretty bad.
Old Sep 13, 2007 | 06:04 PM
There are plenty of 4.30's out there.
digitalracer
May 16, 2016 03:57 AM
boogiewoogie
Aug 29, 2015 01:03 PM
digitalracer
Aug 17, 2015 06:01 PM
boogiewoogie
Aug 17, 2015 12:47 PM
msane99
Jul 11, 2015 08:08 PM
