fuel guage empty light
Old Sep 12, 2007 | 06:53 PM
blue87's Avatar
did 87 trucks come with a light that comes on when the fuel level gets low?
Old Sep 12, 2007 | 07:16 PM
aviator's Avatar
Mine did it would come on when there was about 80km range left in tank or a little less than 10L. My 94 [3rd gen] is supposed to have one but no one I've spoken with has ever had one that worked... even from new.
My mech. told me that it is a seperate sensor on the sender that triggers it and it [the sensor] can go bad.
Old Sep 12, 2007 | 07:34 PM
DeathCougar's Avatar
My SR5 clusters do not have the working light, but the Non-SR5 one in my 86 had the light. All my MR2's, which have Tachs, have the light, so thats weird.
Old Sep 12, 2007 | 07:35 PM
Trumpfan's Avatar
I've got an 86 it seems to come on at about 10L/80km/50mi like aviator said.
I'm not certain because I've got an SR5 guage cluster but the light is in the lower R/H corner. shouldn't be too different from your truck. If yours is working.
Old Sep 12, 2007 | 08:40 PM
longhungsilver's Avatar
im pretty sure its sposed to have one.. my 89 has a spot for the light but it never lights up...i figure the bulbs burnt out but im to lazy to fill it up and i dont believe in letting a tank get that low before filling it up anyways (dont like water getting into the injectors at all)
Old Sep 13, 2007 | 12:22 PM
aviator's Avatar
They had it in the DLX cluster also but as I recall the light was in the opposite corner.... on the 3gens [89-95] the light is supposed to be a little red diode thingy in the upper left corner of the fuel gauge according to the owner's manual... does anybody's light actually work? should start a thread about that....
Old Sep 13, 2007 | 12:48 PM
javadoody's Avatar
i can see where the light is supposed to be, next to the fuel gauge. it's never come on, and i've run on fumes on occasion.
Old Sep 13, 2007 | 12:56 PM
Blurr's Avatar
the light still works in my 93. it is right next to the fuel guage
Old Sep 13, 2007 | 07:25 PM
blue87's Avatar
what does it loog like when it lights up
ex: the oil light looks like an oil can and the motor light looks like and engine so i take it the gas one must look like a gas can. or does it say get gas soon?
Old Sep 13, 2007 | 07:28 PM
881stGenRunner's Avatar
yes there is one. my 88 sr5 has one that comes on. it is right above parking brake light. it is a kinda burnt orange/amber color. I cant recall right now if it says fuel or not but it is very obvious
Old Sep 13, 2007 | 08:05 PM
aviator's Avatar
I seem to recall it said LOW FUEL, but I might be confused...
Old Sep 13, 2007 | 08:08 PM
i just refilled my 4runner the other day. if i remember when it gets low ill try to snap a pic of it.
Old Sep 13, 2007 | 08:15 PM
sh0kk86's Avatar
mine doesnt have one, but then its not sr5 or ex cab...
Old Sep 13, 2007 | 08:26 PM
blue87's Avatar
so my truck is an 87 22r 5 speed single cab short box 4x4
is it an sr5?
Old Sep 13, 2007 | 08:34 PM
does your dash have a tachometer and speedometer? if so then you have an sr5
Old Sep 13, 2007 | 08:41 PM
Blue87: Most were not, and did not have the tach. But if it does, chances are the fuel light isn't present, or doesn't work.
Old Sep 13, 2007 | 08:44 PM
thats true since he said he has a 22R, and doesnt have EFI that would lead me to believe that it is a DLX
Old Sep 14, 2007 | 12:07 AM
magicninja's Avatar
Ive got a 94 reg cab, and it looks like it has a light. I've had about 3/4 of a gallon of gas before, and it never lit up. I don't think mine works.
Old Sep 14, 2007 | 12:14 AM
CC_yota's Avatar
My old '87 had one in the right hand corner of the gauge cluster if I remember correctly.Thats the only way I knew when to fuel up because the fuel gauge went out at about 110,000.
Old Sep 14, 2007 | 07:21 PM
blue87's Avatar
ok so i looked really hard with a flash light and i do have the light !!
now i need to see if it works.
is the only way of doing this runnig until you have no gas or the light comes on ?
but i do not have the indash tack so does this mean its not an sr5
