High Revving when shifting
Old Sep 11, 2007 | 02:14 PM
calex's Avatar
Hello everyone. I have an '88 4Runner w/ the 3VZE motor and everytime I shift (while accelerating), the rpm jumps up by about 500 when I put the clutch in. If I'm not on the throttle just before I put the clutch in (ex: while downshifting) this doesn't occur. Does anyone have an idea what this might be? I don't have any problems while idling... After warmup, it's steady at about the 1,100 mark.
Any help or insight would be appreciated.
Thanks,
Calex
Old Sep 11, 2007 | 02:19 PM
Jay351's Avatar
1,100 is pretty high for idle, it should be around 800 when full warmed up
Old Sep 11, 2007 | 02:33 PM
KevinInSac's Avatar
Mine used to idle 900. But then again, that was the cold season...
As far as the clutch thing, you may just have your timing off, and the clutch is starting to diengage while you have your foot on the throttle still.
Old Sep 11, 2007 | 02:42 PM
MudHippy's Avatar
Thanks,
Calex
Normal. To avoid, do like KevinInSac is saying and release the throttle before you disengage the clutch fully(push the clutch pedal to the floor).
Idle specs are 800 rpm (+/- 50 rpm) for the 3VZE, FYI.
Old Sep 13, 2007 | 01:30 PM
calex's Avatar
High Revving
Thanks for the replies!!
It's definitely not my clutch pedal timing. I went back and tested it. Could this have something to do with a throttle position sensor?? or a bad dashpot??? (just shooting in the dark here...).
C
Old Sep 13, 2007 | 01:39 PM
RustBucket's Avatar
Set your base idle down to spec and see what happens.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
