PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 [149] 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. White smoke...
  2. another oil pressure question.
  3. transmission wiring problem
  4. smittybuilt question
  5. Throwout Bearing Removal
  6. turbo- 1980, or 1992 tacoma
  7. No clutch pedal resistance
  8. Marlin shifter seat replacement (need a quick answer)
  9. Suspension problems???
  10. 3.0 V6 O2 sensor install question
  11. Engine Code 51 Need help from the experts.
  12. bolt sizes?
  13. Was the 3vze ever used in japan?
  14. bad vibration
  15. 1uz lexus motor, florida
  16. Power steering pulley
  17. Truck not idling, but good power.
  18. 3vz timing tensioner swap
  19. Code 71 and VAFM connection??
  20. idle problem when on brakes
  21. 3VZ-E Valve Cover Gasket - Lower Mainland Help?
  22. Oil pan bolt size!?!?!? Help me!!!!
  23. Gauge Lights not working, Checked fuses
  24. fuel bowel leak
  25. 3.4 Swap ECU (AT/Std) question
  26. Stock 92 4Runner get's us out of a sticky situation
  27. engine painting questions
  28. Bilstein 5100 P/N for 4" lift?
  29. Power Steering Pump Rebuild or Replace
  30. Starter problems please help
  31. water pump / timing belt...
  32. Transmission issues.
  33. 2.4l striaght pipe
  34. Front mud flap recomendations?
  35. Pretty sure I found my coolant leak (3vz)
  36. want pics of flat or satin black pickup
  37. A/T Slipping when wet??
  38. Exhaust manifold studs
  39. Secondary air valve
  40. @nd gen hood scoop (Need Some Input)
  41. Homemade BJ spacers?
  42. The ultimate redneck yota!
  43. Valve cover cleaning?
  44. 86 4runner engine swap question
  45. shifting problem
  46. Need Some 89 4runner advice
  47. gas leak at idle only?? info needed
  48. Heating and cooling issues
  49. 87 4Runner 22re ticking...
  50. Trying to remove TPS screws
  51. timing cover bolts
  52. 22re miss, stumble, rough running!!!
  53. Carburetor smells
  54. crankshaft and camshaft position sensors?
  55. 22re Timing chain bad....do I replace HG, too?
  56. Trevor's 2wd hill climb!
  57. Head Gasket Recomendations?!?!
  58. 1988 EFI 4x4 Startup problem
  59. need help making custom cold air intake for 93 22re
  60. hesitation. need some feedback
  61. Warm Start Up Low Idle
  62. majorly blown HG
  63. Head and Block Ground wire locations
  64. Does anyone know how to install snorkel on 88 V6 3.0L EFI
  65. Bolting exhaust manifold without stripping threads...
  66. A/c r12 and r134a system questions
  67. 1988 4x4 New stereo install ?'s?
  68. 4 runner roll bar bolt size???
  69. 1995 4Runner Problem - Dies while running - now won’t start
  70. Brake hard line leaking at caliper
  71. Suspension lift
  72. parking brake cable confusion
  73. easier throttle body cleaner?
  74. Need new engine!!!
  75. 3.blow
  76. exhaust woes...
  77. cold start injector banjo bolt thread size?
  78. Time for a 3.0 LongBlock, post your sources!
  79. bent axle shaft?
  80. Alternator belt won't stop squeaking
  81. 3VZE Power Steering problem
  82. searching for photos
  83. 3.0 timing
  84. Grille's
  85. Losing Power .... please help
  86. HELP FAST... Oil to cylinder head!!!
  87. Temp gauge weird out please help!!!
  88. lift on 94 pu 2wd
  89. 22RE- It's almost there, but I got a lotta questions thread...
  90. Finally getting A Yota!
  91. Thoughts on no fuel / no start
  92. 22RE Timing Problems
  93. Clutch differences between 87 runner and 90 truck?
  94. 88 and up, ifs steering box seal replacement!
  95. 91 pickup Passing IM
  96. Wierd lookin truck
  97. day time runing lights 94 runner
  98. painted interior?
  99. engine question about '87 4runner
  100. replacing exaust manifold gaskets... will I need new studs?
  101. 22RE intake install
  102. Cheap Cab Noise Reduction!
  103. Cooling question.
  104. god-awful gas mileage
  105. 93 5-speed transmission query
  106. engnbldr master kit
  107. 3.0 Piston- Ever seen this?
  108. 22re Wierd overheating issue
  109. weird idle help please!!!
  110. Hitch Interchangeability -Help-
  111. Tailgate Capacity?
  112. Front wheel wobble
  113. Missing front skid plates
  114. Will a leaky exhaust pipe cause burnt exhaust valves?
  115. electrical: battery or alternator or other??
  116. Manual Locking Hubs compatability
  117. E-Locker gear delima
  118. bumpers, bumpers, bumpers... for a 3rd gen PU
  119. Anyone else's foot too big for the cluthc pedal?
  120. toasted ring n pinion....
  121. Exhaust tips???
  122. Cleaning engine compartment
  123. best place to buy a speedometer cable?
  124. Pulls to the left, steering wheel crooked, vibration
  125. New Bumper!
  126. wheres the brake light fuse???
  127. Oil Pressure related to chain slap?
  128. Front drive shaft replacement
  129. Pros and Cons new springs or aals
  130. How many Quarts of oil does the 3.0L V6 manual Transmission take??
  131. Dropping 22RE in '94 pickup
  132. Timing belt problem!
  133. 88 pick up 4WD manual steering box leak
  134. My 22RE Rebuild + Prettification effort
  135. truck bed liner for the rear cargo area
  136. Need help, cant get 4x4 working after engine swap.
  137. Transfer Forward shifter to Top Shifter
  138. stupid carb fitment question
  139. Newbie steering dampner question
  140. Need help routing the small PVC hose 3VZ
  141. 94 3.0 wont start
  142. Seafoam to Find Vaccum Leaks!!!
  143. good deal?
  144. '02 LTD issues
  145. Why do you lower air pressure in the snow
  146. What is this thing in front of the radiator?
  147. Engbldr Street RV head
  148. 1988 3VZE Wire Harness
  149. 22RE crank pulley install
  150. 3.0 rod knock? Change bearings in truck?
  151. front axle locker question
  152. Runs rich. Jumping. Loss of power?
  153. 86 pickup lift kit work on a 86 4runner ?
  154. 22RE oil pump bolts
  155. 1st gen 4runner exhaust
  156. Parting out 92 4x4 4runner
  157. quick lift question
  158. probs. after new headgasket
  159. Has anyone line-x'd their 1st gen top?
  160. ? about changing motor
  161. Shifter Moving All Over While in Gear!! 5spd
  162. Surging! Need help!
  163. isr mod :)
  164. 22RE Rebuilt - had chatter??
  165. First Gen Runner w/IFS can't decide on lift
  166. High Nitrous -> Error 71 -> No Smog Cert for you!
  167. My new first gen! (with a few pics)
  168. coolant temp problem
  169. '89 Pickup 22re leaky coolant in cab
  170. power steering
  171. Advice on electric fan......
  172. Broken antenna
  173. Hilux Surfing site back online
  174. 92 3vz-e into 90 wiring harness difference
  175. Manual hubs repainted
  176. front right side is low?
  177. 3rd gen Taurus fan
  178. C-Rok bumpers: nice style, good model for DIY fab?
  179. Code 42 but I have a mechanical cable?
  180. 22RE- new oil pump install.
  181. Bad fuel/air mix
  182. Wilderness rack installed, 1st gen 4runner
  183. Rear Bumper Build (Pic Heavy)
  184. Is there a bell housing bolt patern guide???
  185. would you drive with out a hood?
  186. 90 tailgate - jambed up - suggestions?
  187. 2nd Gen face lift to 3rd Gen..Possible?
  188. Most Common Engine Oil Leaks ?
  189. some toyota dream cars in australia
  190. New yota old engine
  191. 90-95 4runner led swap list
  192. Bad MAF?
  193. Signs of a headgasket leak?
  194. 95 runner manual swap help!
  195. quick taurus fan question
  196. pitman arm / idler arm thank god
  197. power steering vacuum lines help
  198. Rear axle seals With ABS
  199. Check Engine Light help
  200. New truck! Back in business!!!
  201. OEM brushguard
  202. best header & air filter set up for 93 22re
  203. *sigh* What is a code 43 on a 22re?
  204. Power Steering Gearbox Leak around Adjusting Screw. Can I....
  205. '88 2WD Pickup Parking Brake Cables
  206. No clutch
  207. oil pan and pickup reinstall
  208. i wanna put a newer tacoma or newer 4runner grill in my 90 4runner
  209. IACV stuck bolts
  210. 1987 Toyota Pickup. Questions.
  211. Torque Converter whine
  212. Catalytic converter thief
  213. Popping noise comming out of exhaust after head swap
  214. valvetrain ticking?
  215. Another input shaft bearing question!
  216. Weber carb adjustments
  217. Mirror siding stuff removal...
  218. Best air intake system?
  219. acceleration issues
  220. H4 Conversion Product Question
  221. runnerboyy's 198? 4Runner Build-Up Thread
  222. Where do I get this injector part???
  223. Big Day for my 87.
  224. Have you ever noticed....
  225. TVV switch port broke...CEL on
  226. Loosing Mind Injectors wont work
  227. the 4wd indicator light ghost!!!!
  228. Gas Hand Waving Like A Fool!
  229. yes another head gasket
  230. Front Differential Swap
  231. Relocating Radio Antenna
  232. Recent Tire Wear Issue on Front
  233. help... wheels and tires.
  234. LESSONS LEARNED from 22RE head gasket R&R
  235. timing confusion
  236. When to replace 02 sensor
  237. fuel line banjo bolt crush washer
  238. 22re running rough
  239. Taco brush guard on 91 pickup?
  240. 1993 Toyota Ext Cab V6- purchase help
  241. Ghost within, causing probs
  242. Where is starter relay?
  243. How's this new Yukon Zip Locker?
  244. Post pics of 90-95 4Runner IFS lifted pics
  245. Help a Newb
  246. 87 4Runner Emission Troubles
  247. Downey Intake and Headers = Ruined Cat?
  248. idleing high at normal temp. weird idle
  249. rear power window switch
  250. Been a while
