E-Locker gear delima
Old Oct 12, 2009 | 05:34 PM
olharleyman's Avatar
Can someone clarify for me if a regular 8"ring and pinion will fit a e-locker from a TRD Taco, I keep seeing yes it will then read on about it somewhere else and it Say's you need a special gear and pinion oh the confusion.
If I need a special ring and pinion where can I find a 5.29 set up for one going to install in my 84 4 cylinder front axle and yes I know I need to clearance the axle for the 3rd member.
Old Oct 13, 2009 | 01:22 AM
tc's Avatar
tc
Here's the point of confusion - a "normal" Toyota 8" is not "normal" on a Tacoma, as the non-TRD uses the "8.4" diff, which uses different gears.
So, yes, you can use any 8" <1995.5 gearset from a pre-Tacoma truck/4Runner, or even 3rd gen 4Runner.
I would be concerned buying gears from anywhere that didn't know that ...
All that said, high pinion from a 80-series Landcruiser would be the hot setup for a front axle. 30% stronger, and better driveline angles.
Old Oct 13, 2009 | 02:54 AM
crolison's Avatar
All you need is a v6 gear set for your elocker
Jun 1, 2021 01:51 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
AaronM
Jul 8, 2015 07:15 PM
