valvetrain ticking?
Old Oct 9, 2009 | 07:02 AM
93yota93lude's Avatar
valvetrain ticking?
hey my valve train is ticking i know its caz old motor worn out question is best way to solve this?? adjust the valves or go with new internals? or leave it??
Old Oct 9, 2009 | 07:11 AM
Jipopotamo's Avatar
I got a ticker too. I made sure the valves were set correctly which they weren't and it lessened some. ENGN BLDR told me awhile back that after a compression test if things aren't broke, don't fix it. Run a comp and if numbers are good, I'd be ok with it.
Old Oct 9, 2009 | 07:25 AM
awesome thanks ill run comp check tonight after work im sure there good just on interstate with no music on kind of annoying after a while haha
Old Oct 10, 2009 | 12:40 PM
NYChopshop's Avatar
go get (or pull out of the garage) an automotive stethoscope. Make sure its actually coming from inside your valvetrain. I had a noise I thought was loose valves, but it was actually just noisy fuel injectors. Compression tests are great, and I totally recommend doing one, but pinpointing the noise should be your step #1.
Old Oct 10, 2009 | 03:53 PM
ok cool ill do that at work tomorrow
Davebarbier
Nov 3, 2015 03:28 PM
kawazx636
Sep 29, 2015 08:22 AM
Tacoma1313
Sep 15, 2015 07:51 AM
ErikZ1220
Sep 10, 2015 04:53 AM
cars-guy
Jul 11, 2015 07:51 PM
