Front wheel wobble
Old Oct 12, 2009 | 08:01 PM
dwnhiller93's Avatar
Front wheel wobble
Hello, just joined the website, I have been lurking unregistered for quite some time now, but decided to join.
Anyways.. I was driving down the road a couple days ago and I heard a rattle coming from my side. I rolled down my window and stuck my head out to see if it was the wheel, and sure enough, the front left side wheel was wobbling a little. I figured it was the tie rod end, both sides had play in them. Replaced the tie rod ends today on both sides, aligned it, and was driving and sure enough, wheel was still wobbling. I jacked it up to check to see if there was any play in the bearings, but no play. So I am just asking.. What else could be making the wheel wobble?
Thanks in advance!
Josh
Old Oct 12, 2009 | 08:02 PM
toyota4x4907's Avatar
Are the lug nuts tight?...
.....and still there?..
I guess it would help to know that its a 1988 toyota pickup, 4cyl 22r.
Old Oct 12, 2009 | 08:03 PM
lug nuts are definitely tight
Old Oct 12, 2009 | 08:04 PM
Are any of your ball joint boots broken?
Old Oct 12, 2009 | 08:07 PM
Nope, I checked those as well. I also read that sticking a crow bar under the tire and pulling up a few times will check to see if there is play in the ball joints? Not sure if its true but I also tried that. Its very solid.
Old Oct 12, 2009 | 08:51 PM
olharleyman's Avatar
Bent rim?
Old Oct 12, 2009 | 09:06 PM
Tubbyfatty's Avatar
Originally Posted by olharleyman
Bent rim?
Or out of balance tire?
Old Oct 13, 2009 | 07:23 AM
it could be an out of balance tire..how do you fix an out of balance tire? (Sorry I am a noob)
Old Oct 13, 2009 | 07:26 AM
theAuthority's Avatar
User Requested Ban
take it to a shop, tell them to balance it ..... pay $25 and go drive it again
Old Oct 13, 2009 | 07:30 AM
alright, thanks. I hope that its only an out of balance tire!
Old Oct 13, 2009 | 08:57 AM
Turboz's Avatar
Jack the front end up an grab the tire and see if it moves. if there is free play your hub may be loose. Could just need to tighten the nuts or maybe the wheel bearings never got repacked with grease and are bad
Old Oct 13, 2009 | 10:10 AM
Jay351's Avatar
Check for play in the balljoints (And grease them!!!), check for play in the idler arm and pitman arm and make sure your wheelbearings are in good shape...
Old Oct 13, 2009 | 10:27 AM
camo31_10.50's Avatar
man...my freakin '86 has a bad wobble on from abot 45-55mph..i can tell its steering related..because the steering wheel shakesback and forth kinda slowly...its not like a vibration like an out of balance tire or somethin..i'm gonna check my idler arm..my bj's and the pitman arm..see whats up..hopefully it aint anything bad.........
Old Oct 13, 2009 | 02:27 PM
There is definitely no play from the bearings or hub. That is the first thing I checked when I saw the wobble.
Also after talking to my dad today, he doesn't think its an unbalanced tire. I forgot to mention there is a sound.. Like a chain or something.
Old Oct 14, 2009 | 05:39 PM
Hey so got the front tire balanced.. didn't change a thing. Also greased up the ball joints.. didn't change anything either. Any other ideas?
Old Oct 14, 2009 | 05:56 PM
securekey's Avatar
If it makes a chain like sound I am guessing bearings... or cv joint. Pitman arm / idler arm could give you wobble but i don't believe there would be a chain/metal like sound. Usually just slopped steering.
btw: is the sound constant or just when you turn? etc...
Old Oct 14, 2009 | 06:24 PM
9o7yota's Avatar
My buddies tire started to wobble once..he had a bent axle... if u have cv joints instead of an axle u might see if those arent bent either.. just a suggestion.
Old Oct 14, 2009 | 06:36 PM
The sound is constant. But gets louder when I hit any bumps with the tire. Also I forgot to mention, I am pretty sure it started after I changed out the roters and calipers around a week ago. It could be the bearings, but there is zero play with I pull on it, and I repacked the bearings really good when I put them back on.
Old Oct 14, 2009 | 07:06 PM
myyota's Avatar
It might be a good idea to pull everything a part again to recheck the bearing and make sure things are alright.
