Code 71 and VAFM connection??
Old Oct 16, 2009 | 03:52 PM
buckz6319's Avatar
Old Oct 17, 2009 | 05:27 AM
buckz6319's Avatar
........................bump...... .....bump.............
Old Oct 17, 2009 | 12:44 PM
buckz6319's Avatar
Old Nov 17, 2009 | 07:47 PM
edwinb4x4's Avatar
Check the connector housing - that is pins and the wiring harness, possible that there's a rust on one the pins or one of the wire is loose or about to break. Use a fine steel brush or a sand paper to clean the pins. For the wires, you will need to slide off the rubber boot to expose the wires.
my 2cents
Old Nov 17, 2009 | 08:24 PM
abecedarian's Avatar
71 is an EGR code.
Why are you mucking around the air-flow meter?
Old Nov 17, 2009 | 08:26 PM
lemme guess... you drive around all day and no code, but 10 miles on the highway, maintaining highway speeds, and the CEL comes on?
Blamalam
Mar 12, 2022 07:34 AM
mussy01
Dec 13, 2016 08:20 PM
wafoogalla
Nov 2, 2016 11:02 AM
scooterpie01
Aug 28, 2015 10:15 AM
raptor510
Aug 19, 2015 02:15 PM
