New yota old engine
Old Oct 10, 2009 | 07:23 AM
davo247d's Avatar
New yota old engine
so i jsut got an 88 ex-cab 22re 4x4 and it has a knocking rod and it needs a rebuild or does any one know an easyer way to fix that and if it does need a rebuild best place to get a kit for it, i looked into engrbldr and for the kit anda cam it was like 260$ let me know what you think
Old Oct 10, 2009 | 07:37 AM
90RunnerRed's Avatar
Congrats on the new truck. A rod knocking is pretty much a full proof indicator you need to do a full rebuild. You theoretically could pull the head off, drop the pan and just replace the one rod, but probably not the smartest idea in the world.
Engbldr makes some awesome stuff. I ordered a front end kit from them and was very happy. I've heard nothing but good things about them.
Old Oct 10, 2009 | 07:59 AM
DeathCougar's Avatar
First you need to determine what is actually wrong with the engine. Don't assume that a rod has a messed up bearing. It could be wrist pin noise, several rods, or any combination therein. Take the engine out, and apart, and start doing some investigating.
If the rods are toast, you likely have hammered the crank. This will require either a new crank, or a crank turn and over size bearings. It all depends on what it looks like when you get it apart. Again, take it all out and apart, THEN order parts.
Old Oct 10, 2009 | 08:03 AM
davo247d's Avatar
alright i will start to do that today lol and i will wait to order parts, thanks for the advice as ive never rebuild an engine lol
icentropy
Sep 16, 2020 02:47 PM
Sleaker
Aug 26, 2020 06:03 AM
Regency
20
Jan 3, 2020 07:43 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
