- Change oil pan gasket and find broken metal and plastic and coolant inside
- 1993 pickup 3VZE engine trouble
- Wheel bearing? How should i know?
- Who's using Toyota filter 90915-YZZD3 on a 22RE?
- Need Tie Rod Help
- I need help finding parts for my truck
- o/d light blinking plus a few other problems related
- W56 center gasket leak - repair idea!
- Custom Interior Ideas
- engine code/ starter help
- A/T Fluid Temp light ahhhhhhhhhhh!
- Metal Trim Around Sunroof Replacement?
- MC 1600lb clutch
- 2wd to 4wd conversion
- RIP 3VZE. I never did like you much.
- fuel pump bracket ?
- Tranny cooler placement
- Question, 94 standard cab truck will a 94 extend cab swap?
- need performance camshaft help
- ifs steering box
- Running Problems? - General Diagnosis Steps for Newbs
- Sensamatic shocks for 90-4Runner
- Toyota dually mileage
- Problem starting: 1994 4Runner 3.0
- Bed compatability questions
- Newb Flywheel Questions
- 22re running really bad, Code 3
- Nasty Vibration while driving: 87 4runner
- need engine guru help, 22-re noise driving me crazy
- electrical problem? input appreciated!
- 3vze valve tick question
- 1995 3VZ Coil - Ignitor Options
- Weasy cams still available?
- Battery spray inside my engine compartment :(
- A/C rebuild - input needed
- changing dist. pickup coil '87 pickup 22r
- The need for speed
- 3vze Timing belt and Cam seals?
- How do I check 3VZE codes? (94 4Runner)
- Rear sliding window replacemt for Pickup
- How Cold Is Your Vent Temp?
- Engine Cut's Out above 1,200 RPM -long'ish
- 95 4runner with auto 2jzgte swap?
- Runner and truck exhaust compatiblity
- No more street tires!
- 20r head swap onto 22re
- what causes soot under my truck?
- rusty fuel line at filter
- New pic and transmission question for '87 4Runner
- 1995 PS lines and brake lines connect???? passenger side frame.
- Engine/Tranny Noise
- problems with starter
- HiD kit 6k finally done with blue halo beam inside.
- Is my starter going bad?
- Door lights and dome light not working. 87 4runner.
- auto trans stuck in 3rd?
- Spark Plug Stuck
- 86 tranny help
- CV boot leak
- trailgear disc brake conversion
- questions about installing temp/compass unit
- will '91 4runner door or window fit '91 toyo pick-up?
- Help deciding what mods to get for moab, 1990 4runner
- Drill out and retap or replace cover???
- CV axle HELP...
- ATM transmission flush question
- Power window issues
- screwy camber?
- truck clunks in rear end several to randomly times on flat ground
- 89 toyota 3.0 rpms wont go over 1000
- 3VZE AFM - Misfire
- MY old girl (a 1990 4x4) has no spark!
- MCo7 = floor board mess
- 88 22re hard start, rough idle when cold....good after warms up
- question about 86 22rt
- 88 4 runner wobbling
- AC Compressor help
- crankshaft seal please read!
- Worst 3.0 mods
- Loss of power in 4runner.
- 22re power loss under load
- Irish Death blew his head gasket...oi! 86 4Runner!
- Just bought an 86' 22r
- help! 22re 199k miles wont start!
- HELP! 22RE timing won't advance, goes dead, no power
- Strange cooling system/charging system problem
- Oil Spill
- 22R-E help please
- Timing guide? 3.0 3vze
- Low Power in a 22RE, running poorly.
- 92 Pickup with strange problems
- Tranny problems throw out pilot syncros help
- Seat belt problem??
- My 4runner has got the shakes, the hippy hippy shakes.
- Greasing Slip Yoke
- 88 pickup 22re O2 sensor plug location
- So you want to steal a 93 runner...
- Shield
- New 4Runner and new problems
- Help me identify these flares *not bushwacker*
- circuit open relay help
- A340h automatic transmission
- interior panels
- Oil Leak- Heads?
- well i finally passed california smog...
- Loss of voltage when braking
- shackle coming up and locking spring up, need some opinions
- Walker Quietflow SS
- no check engine light
- truck wont idle
- newb intro with a ?
- Adding A/C
- New 22re jumped timing chain!
- Did I mess up my diff.?
- yet another weird brake problem
- will the ZUK coil mod help level m y rig from side to side?
- 88 yota will not rev high
- sluggish after head gasket replacement?
- 89 4 runner transmission swap?
- cheap 02 sensor 95 4runner 3.slow
- NWOR Idler Brace?
- wiring gremlin - constant power to wipers, blower motor....
- Responsible for seal leaking?
- 90 22 re tps?
- Running VERY rich after an engine swap...? Any idea's?
- Dies after 5 seconds.... Ideas??
- Getting the kinks out of new 3.0L
- clutch release bearing clips.
- sticky rear brakes/ hand brake- HELP!!!
- Need 22re help asap
- Question on transfer case bearing/mount.
- 86 4runner keeps dying/ rough idle
- 4wd problem. Faulty CV?
- Zelephant's two-tone roller paint job advice/progress thread
- Overheating in 22RE 3,000 miles after ENGBLDR FEK install
- Is this a tranny or clutch issue?
- Engine Noises (3vze)
- Changed my CV shaft, here's my take on it...
- Drivers side manifold on Passanger side head (3.0)
- what lift and gears
- How much does a gallon of POR15 cost in the states?
- Locker doesn't fit?
- Electrical Problem. Need Help Please!
- ARGH! Air box stud removal.
- Tires and Wheels
- Auto tranny to a 22re
- Rear brake hose
- Need help with front end
- Is my engine dieing ?
- Timing ???'s
- Baby Runner got new brakes!
- fuel pulsation dampener 3vze
- 3.0L V6 New Rebuild, No Power
- Brake Problem Fixed!!!!
- 22re + man tran + tcase install
- whats the best fuel additive?
- Suspension Travel/wheel rubbing
- No O2
- I need a dashboard 1994 toyota pickup.
- Looking into buying a "Performance" 22RE on Seattle CL...
- need help during shifter bushing install
- JB Weld the ehaust???
- 33 mud terrains on a 2.4 to much?
- Rebuilt 22r Still smokes and burns oil
- Think i need a new rear axle???
- 91 4Runner sunroof opens but wont close
- NO CLEARANCE after Valve Job Help Thanks
- snapped OFF SHOCK MOUNTING BOLT!!!!
- 88 yota bein funny
- Need some advice plz
- rear seats in '91 p/u
- Codethrowarama: Codes 25, 26 and 52
- Exhaust system?
- vacuum line?
- Overheating or faulty guage??
- 22re woodruff key size!!!!!
- Where did this ECU come from?
- Need help please
- Better Power and MPG for my 88 4runner?
- Intake Gaskets...
- 4runner keeps dying on me - help
- 22re wont start AGAIN
- 4x4 transmission questions plz help
- Cigarette Lighter Amperage?
- New to the 3.0 got ???
- 4Runner Vent Panel Behind Door
- Another idle problem
- Mpg sucks....
- Tire chains on IFS?
- 86 4runner Weatherstripping replacement
- Blue Thunder is wounded, need help in denver area.
- When stepping on brake engine almost stalls.
- Ball Joint Spacers?
- Codes here, sensors good tho
- Ignition problems--Need help!
- Smittybuilt XRC10 Comp and ARB bumper question
- PreRunner capable SAS?
- 4x4 does not work
- is it my clutch or tranny...crazy vibrations
- vacuume leak
- 35's no lift on a 3rd gen pickup??
- Doubler kit doesnt fit
- 3rd member question - 81 into 87 front?
- New 3VZE (rebuilt) valve gasket leak and rough start
- idle speed adjustments?
- Oil pressure Gauge setup wanted 22re
- OME or Bilstein shocks?
- auto shifter removal. need help
- GTS bug guard
- broke out a lift block now fixed and no brake pressure!!!!
- fill plug stuck
- why my 3vze was running weird post answer but had to start a new thread because....
- Flywheel/Clutch dust shield?
- number 2 cyl low compression.
- What are these VSV for?
- Marlin crawler 3rd members.
- ecu upgrade
- gmc alternator swap onto 22re
- Clinometer Idea
- what to do with my turdbo 4runner
- Exhaust bolt size
- Cross member/ transmission bolt size ?
- u-joint yoke question
- 87 cruise control
- Good machine shop in Knoxville?
- 2 Oil Pump Questions
- Have questions on auto to manual swap
- 22r rebuild, lost #3 cylinder
- No Injector pulse
- Hood interchange
- Gear oil coming out arb compressor exaust?
- Alternator Or Short?
- help with lc coils
- Zuk Mod on my 95 3.0 Pickup w/ Pictures
- Wiper issues: 95 4Runner
- part #
- ZUK mod with TJ coils (with pics)
- My new (to me) runner
- The Crankshaft Pulley bolt from Hell
- IFS "upgrade" parts
- 1990 efi bent arm
- Newby - Diagnosing Oil Leak source?
- water by-pass outlet.. sensor
- 22RE cold start problem
- '89 4runner: sideview mirror options?
- Rough Idle (vacuum leak?)
- Rear mounted fuel tank on 88 4runner?
- Short shifter
- 4runner build, frame/ suspension questions...
