electrical problem? input appreciated!
Old May 4, 2010 | 10:04 AM
YotANo0b's Avatar
From: live in arizona at this time.. intending to move to minneso-rusty-ta... hope my bed holds up! :P
88 p/u 3VZE.. just replaced a ground from block to master cylinder that was cut by previous owner for w.e. reason. also replaced jerry-rigged fuse box power supply wire and battery ground. added new ground off block. all wire used was 6gauge. when putting the wires back in the battery connector i put the wrong wire in the positive connector and the connector sparked and smoked when i placed it on the terminal. so switched them and bolted it all back together.. then tried starting it and the truck started then idled really low and would cut out if i didnt give it gas.. really crappy running and even a funny popping noise from engine (not backfire).. im scared i screwed somethin up real bad.. please help desperate newb!
MO transplant
Apr 23, 2023 11:58 AM
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Poncho0206
Jul 10, 2015 06:21 PM
karbin
Jul 5, 2015 11:37 PM
