When stepping on brake engine almost stalls.
Old Apr 22, 2010 | 05:32 PM
DREDFIELD's Avatar
When i step on the brake the engine almost stall but wont. I disconnected the vacuum and the censor on the master cylinder and it still will do the same thing. Not sure what the problem is, Please Help.
Old Apr 22, 2010 | 05:36 PM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Uh, auto or manual tranny? If manual are you steppin' on the clutch first, because hitting the brakes without hitting the clutch will def. cause a stall.
If auto, I couldn't even begin to hazard a guess as to what's wrong.
Old Apr 22, 2010 | 05:45 PM
DREDFIELD's Avatar
Its a manual but thats not the case it is something to do with the power booster or power brakes. I can have it in neutral and hold the brake and it will almost stall.
Old Apr 22, 2010 | 05:56 PM
kev's Avatar
kev
You probably have some vaccuum deficency.
Old Apr 22, 2010 | 05:59 PM
DREDFIELD's Avatar
But i disconnected the vacuum hose and pluged it. It still almost stalled when i step on the brake.
Old Apr 22, 2010 | 06:18 PM
yotaman85's Avatar
check to make sure your brake light wire or brake switch wire isn't grounding out somewhere.
Old Apr 22, 2010 | 06:37 PM
mattaway's Avatar
Turn your idle down....
EDIT: Should be set to 750 rpm, if you don't have a tach, do it by ear.
Old Apr 22, 2010 | 07:02 PM
DREDFIELD's Avatar
Ok thank you
Old Apr 23, 2010 | 11:26 PM
mattaway's Avatar
Well... how'd it work out for you?
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
Jnkml
Jul 6, 2015 01:20 PM
