no check engine light
Old Apr 27, 2010 | 09:08 PM
therunner6's Avatar
I put my 1990 4runner on its side, and after rolling it back and trying to start it it wont start. when the ignition is on i have no check engine light. it turns over but the fuel injectors arent firing. i have fuel in my fuel pump all the way up to my manifuld, and after that there is nothing. any ideas?
Old Apr 27, 2010 | 09:45 PM
yayfortrees's Avatar
EFI relay or fuse? What side was it on, and was there any significant damage?
Somebody else will have to say whether or not the ECU is located in the same position as the trucks, which is behind the passenger side kick panel. If you crunched that area from the outside, it's possible a wire harness is pulled out, or a wire or wires are pinched and grounded or shorted out.
Unfortunately, all I can do at this point is guess.
Old Apr 27, 2010 | 09:57 PM
ChefYota4x4's Avatar
Yay said;
That's exactly what I was going to suggest. My friend was hit on the Passenger side of his 88, cracked the housing to the relay and it wouldn't start. Some body work and a new relay housing and voila!
Good luck, Runner6.
Old Apr 28, 2010 | 10:03 AM
therunner6's Avatar
I put it on the driver side, only significant body damage was rear quarter panel on drivers side. Oil came through the pcv valve and out my air intake, that's all cleaned up, but the fuel infectors won't fire. Yes it's te v6 efi
Old Apr 28, 2010 | 10:16 AM
I'm still guessing it's the relay or fuse, probably just came loose.
Good luck and keep us posted on the progress.
Old Apr 28, 2010 | 10:21 AM
therunner6's Avatar
Would that be in te passenger side kick panel? Because I heard it can also be under the center console, I'll look later today and let you know what I find out, thanks
Old Apr 28, 2010 | 10:28 AM
thook's Avatar
The CEL tells you if the ECU is getting power on not. It could be what's suggested already, or the fusible link from the battery. You can visually inspect the FL or the EFI fuse, but the relay you'll have to listen for. That is if the first two culprits have been ruled out. It'd be handy if you had a volt meter, but let's say the FL and fuse are fine. When you turn the key on, you should here the relay click. If not, then it's bad. Then again, even if it does click and you're still not getting the CEL, it could still be bad. Then you'd have to just test it with a meter or stick another one in and see what happens.
Old Apr 29, 2010 | 02:12 PM
therunner6's Avatar
Just to keep everybody posted, my computer is shot
Old Apr 29, 2010 | 05:59 PM
Do you have a V6 or 4 cylinder? I have an ECU for a 3VZE. I don't know much about it, other than it worked 3 to 4 years ago in a donor truck I got recently. The guy had already pulled the motor, so I couldn't test it. It has set in the truck since the last time he drove it. Since I can't guarantee it's condition, I would let it go for cheap.
Old Apr 29, 2010 | 07:03 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Well, 1st of all, you'd have to compare the numbers on the tops of the computers.......the numbers don't match, it won't work.....
Old Apr 30, 2010 | 05:17 AM
thook's Avatar
Just curious.........how'd you determine that?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
