1994 22re coolant leak, back of block
Old Jan 28, 2010 | 09:44 PM
Squeebs's Avatar
Howdy.
I discovered today that I had a pretty bad coolant leak.
It was a warm day, so I had the temp control set to the coolest (AC wasnt on) on my way to the bank. I came out from the bank and see about half a quart of coolant on the ground.
It was coming from the back of the block, and seemed to be running down mostly on the driver side of the bellhousing. If I run the heater when I drive, it doesnt drip AT ALL when I it off.
Ideas?
Carpet is dry, and all the coolant hoses going into the cab appear to be dry.
Maybe a freeze plug?
Head gasket? I don't think its a head gasket, it doesn't seemed to have lost any power.
Old Jan 28, 2010 | 10:33 PM
r8cfreak's Avatar
theres a by pass hose on top of the block between the fire wall check that its shaped like a c my hose went and i had the same problem hope this helps
Old Jan 28, 2010 | 11:11 PM
geTBeNt2NIghT's Avatar
There is a plate that bolts to the back of the head. Its a coolant journal. More than likely thats your leak. Not sure if you can buy just that gasket or if ya have to buy a whole head gasket kit. Its real hard to see cause its right against the firewall. Get an inspection mirror and a flashlight and check it out.
Old Jan 29, 2010 | 05:19 AM
Squeebs's Avatar
thanks
Old Apr 30, 2010 | 05:25 AM
de6w6it's Avatar
any idea what it or the gasket for it would be called? I am having the same issue, and it is definitely coming from this.
thanks
dewitt
Spicer
Apr 7, 2026 07:17 PM
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Old Red 94
Jun 16, 2015 08:32 PM
