auto trans stuck in 3rd?
Old May 1, 2010 | 06:44 PM
dragondriver5's Avatar
This is on a 87 4x4 Toyota truck and I believe is the A340H auto trans
Problem is it hardly moves when I put it in drive. It's like it's stuck in 3rd gear. I can manually put it in low and two and then into drive and it's fine but it never down shifts
also the Eco and overdrive buttons dont seem to do anything or even light up
any ideas?
Also the fluid level is fine but I have heard it can clog?
Thanks!
Old May 1, 2010 | 06:48 PM
ScottyC's Avatar
Bad shift solenoids. Here is a write-up I did a few years ago. Even has links for where to get the new solenoids.
http://www.toyotaholics.com/support/...sp?TOPIC_ID=19
Old May 1, 2010 | 07:30 PM
Thanks for the help
Old May 1, 2010 | 08:00 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
there's also this... I remember "limps home" so see if you can find that phrase and what is says... I'm just too tired to find it now... But it's in the 1st couple of posts.
http://www.pirate4x4.com/forum/showthread.php?t=587521
Old May 1, 2010 | 08:23 PM
Interesting.. I found the "limp home" info, which does describe my situation except that I've not seen my cosole lights on at all (maybe unplugged? no matter what I do they don't light up)
Old May 2, 2010 | 11:24 AM
InternetRoadkill's Avatar
It's been a while since I've been in a 340, but are all the solenoids identical including the one in the transfer case? I need to replace all of mine. They are getting really annoying.
Old May 3, 2010 | 09:11 AM
weaselman's Avatar
Had the same problem as you. And I replaced solenoids and fixed the problem
Old Jun 8, 2010 | 08:47 AM
yodercrawler55's Avatar
Yea I have had issues with mine since i bought mine 2 years ago. I just ordered some off the Makco site, thanks scotty that was a huge help!
Jun 1, 2021 01:51 PM
this_guy
Jul 31, 2015 01:27 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
andrewtexas123
Jul 14, 2015 04:29 AM
Poncho0206
Jul 10, 2015 06:21 PM
