Locker doesn't fit?
Old Apr 25, 2010 | 01:18 PM
DeadWrong's Avatar
Locker doesn't fit?
I recently received a spartan locker in the mail and went to install it with a friends help today. When we went to put the side gears in the carrier, they didn't fit. we measured the old and new and the locker's sidegears are 200th bigger, this is also the case with the center pin. Did I get the wrong locker? the box is labeled as a 4cyl toyota 8inch. (which my truck is) Was there a mixup at the factory ? Is there something we are missing? Any help is appreciated
Old Apr 25, 2010 | 02:04 PM
INFINITY's Avatar
might have to grind the carrier like with a aussie locker. it is a MFPITA and oh yea sucks grinding the carrier. i would call the company first though.
Old Apr 25, 2010 | 03:31 PM
Matt16's Avatar
The cases are cast iron, any surface on them that is not machined is not at all a precise, sometimes the side opening where you access the spider gears is a hair too small to get the new locker in, due to casting imperfections. Just grind it down a hair and be done with it. It will not reduce the strength of the case unless you're removing a LOT more than 1/200" of material. I've had to file out a bit of material on both diffs I've installed lockers in.
INFINITY: Actually, I found grinding down the case a touch took about 5 minutes with a metal file or 30 seconds with a Dremel. Not a big deal at all.
Old Apr 25, 2010 | 03:47 PM
INFINITY's Avatar
try it on a dana 35
Old Apr 25, 2010 | 05:02 PM
Matt16's Avatar
Completely different kettle of fish. Apparently the Dana 35 case isn't strong enough for a ratcheting autolocker and the axles can't handle decent tires with a locker.
Old Apr 26, 2010 | 01:32 PM
DeadWrong's Avatar
I think you guys have the wrong idea of my problem.. I have a 2 piece carrier. 4 spiders 2 side gears, the side gears of the locker don't fit in the bore of the case, where the factory side gears go.
Old Apr 26, 2010 | 03:48 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
4 spiders is a V6 rear... or the V6 cased infamous 4:88's you can not regear...
dang dude...
http://home.4x4wire.com/erik/diffs/
V6, Turbo or 4:88's and yes, two of those are used with "4cylinder's"
Old Apr 26, 2010 | 03:51 PM
Jay351's Avatar
A factory 4.88 is easy to distinguish from others, with its offset pinion and thinner ring gear.
If you have a v6 diff that 4cyl locker wont work.
Old Apr 26, 2010 | 03:56 PM
That's why I try Toyota...
Way too many weak links in a Chrysler...
Jeep guys and Toyota guys live for this rivalry, but TBT Dana's can't handle a "Ford 8""
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
crashburnoveride
Jul 10, 2015 06:39 AM
icentropy
Jul 9, 2015 02:12 PM
