4Runner Vent Panel Behind Door
Old Apr 22, 2010 | 08:31 PM
B4Runner's Avatar
Exclamation 4Runner Vent Panel Behind Door
I've seen this explained in a thread before, but have had no luck finding anything now.
I want to run my antenna coax though this vent to the inside panel
What I need to know: Does the vent behind this panel lead to the inside panel?
I know its tricky to get it on and off, too. So any advice and answer you can give me would be great.
Thanks!
Old Apr 22, 2010 | 09:11 PM
B4Runner's Avatar
25 views and no answers. C'mon guys, someone has to know.
Old Apr 22, 2010 | 09:21 PM
dropzone's Avatar
Fossilized
it vents the cab. just like on the pick up. why does everyone expect an answer 30 minutes later
Old Apr 22, 2010 | 09:25 PM
B4Runner's Avatar
40 actually. I know it vents the cab. I was just wondering if I'd be able to route my coax through it to the inside panel.
Old Apr 22, 2010 | 09:29 PM
dropzone's Avatar
Fossilized
must be a member of the instant gratification generation
Old Apr 22, 2010 | 09:31 PM
malteserunner's Avatar
You could run it through there if you'd like. When you remove the vent cover, you'll break the clips that hold it to the body. No way around that. You can get new clips from the dealer, or one of the online vendors.
Old Apr 22, 2010 | 09:32 PM
B4Runner's Avatar
I admit I am when I'm hoping to find info about something that's holding me up.
Old Apr 23, 2010 | 07:44 AM
874runnersr5's Avatar
its kinda tricky to take them off, i tried at the local junkyard on the 4runners and to be honest, i ended up breaking the little clip tabs.. also there is a vent thing that ends into the cab.
Old Apr 23, 2010 | 03:48 PM
InternetRoadkill's Avatar
The louvers are impossible to remove without breaking the clips. You could run a coax under there if you really too.
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
shar
Jul 9, 2015 12:38 PM
Cplmike
Jul 8, 2015 08:47 PM
elwood73
Jul 5, 2015 07:07 AM
