what lift and gears
Old Apr 25, 2010 | 01:50 PM
OL' YELLA's Avatar
what lift and gears
i got a 88 truck with a V6 and ifs i currently have the t-bars cranked up and running 33x13.50 TSLs and they only scrub when the trucks completly flexed out and then it only touches under the rear fender wells but im looking at getting 34x10.50 LTBs or 35x14 boggers and would like to put a small suspension lift like maybe a 2-3 inch lift i really like the way the tires are tucked up under the fenders now so i really dont want to lift it much more then that and i was wonderin if any one even made a lift i though i saw a kit from daystar that was like 2.5 inches ? and i will not have a body lift on my truck. also going to get new gears and a locker i was wonderin if any one had any input on what gears i should stuff in there this is my dd and would like to still be able to cruise at hwy speeds 60-70 mph with out havin the motor reved to high any input would be great thanks
Old Apr 25, 2010 | 01:56 PM
vital22re's Avatar
totally a bro
there is a little button up top of the webpage that says search.. USE IT BEFORE YOU ASK QUESTIONS THAT HAVE BEEN ANSWERED A MILLION TIMES.
Old Apr 25, 2010 | 02:07 PM
yayfortrees's Avatar
One thing about a body lift, it makes it a lot easier working on the truck. I would hate working on one of our trucks without it.
I'm curious, are you running stock upper control arms, or something like fabtech? With the t-bars cranked, how much is your front suspension preloaded? I.E. at rest, how far away is the UCA from the bump stop? If it's really close to the bump stop, (how Fabtech recommends in their instructions), you don't have much down-travel available. You don't need down-travel for hitting bumps, but when you hit pot-holes, the suspension can't 'match' the road, causing your truck to fall into the hole, only to bounce out really hard.
As far as what gears to run, there's a sticky in the forum for just that.
coffey50
Jul 28, 2015 10:55 AM
Backcountry411
Jul 24, 2015 08:06 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
PlayAwhile
Jul 20, 2015 11:36 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
