- v6 for sale
- IFS diff gear questions
- 4running like crap...
- Won't start...electrical..please help!?
- Brake upgrade question
- Patching the PAIR/intake hose
- anyone recognize this part/ steering clunk
- Darn Alt belt
- High Idle Troubleshooting Questions
- Wiring
- Aussie locker install problems.......
- looking for engine
- driveline or pinion
- 86 auto trans only shifts manually
- Got my CB installed (pictures inside)
- Bed caps
- 89' starter contacts
- Getting better MPG with out the snake oils
- Maintenance/Repair related question...
- Brake upgrade (qausi-writeup)
- fresh 0 miles rebuilt 22re 5 speed 5.29 37's?
- My VAFM SWAP...Whad u think??
- Got a new(to me t4r) // High idle when warm/cold 91 4runner v6
- Knocking noises at initial start
- 3vze help needed!
- A/c leaking water on floor?
- steering wheel still shakes after frontend work
- Keeping 1993 Toyota on life support! HELP!
- massive sqeaking from driverside wheel
- 3vze camshaft sprockets
- Fiberglass Fenders and 31" tires on a 2wd
- cant get into reverse without grinding...
- OME 880 install P.I.A.
- 22re head gasket (drain oil and antifreeze before??)
- trying to start body lift..
- air conditioner clutch.
- clutch clunk after 1" body lift?
- Can an 87 22re fit in a 93 pickup?
- fuel pump
- 95 4runner replaced timing belt, now it won't start.....
- herculiner and mods to my 87 pics
- E brake qestion
- Swaping IFS front Diff
- Something Snapped off !! Help !!!
- how much oil in R150F trans?
- 2UZ-FE in 2nd gens runner
- 1986 pickup tranny makin some noise after oil change
- White exhaust smoke!!
- New to toyota "pickup" - clutch problems
- 3vze Crank Gear-How do you get this thing off?
- Wobbly Auto Shifter
- Knock Sensor, will it run without it?
- 94runner- Rear end sag remedies?
- Loaded 4runner, ZUK mod test. Pictures
- 3vze Water Pump Replacement
- I got it, I got it, I got it !!!!!!!!
- 1995 Toyota Pickup Sputtering/Missing
- Emissions problem or idiot tech?
- The BEAST's altitude adjustment
- 86 4Runner, need some help.
- gas mileage
- New Truck
- engine code 27
- Looking for more amperage from the charging system
- 22re head gasket help!!!!!!!!
- 22r to 22re?
- 1986 22re radiator upgrade question
- Tailgate Cable Sticking
- soft brake problem
- CB antenna on bumpers??
- Gm One wire questions
- header ?
- Grinding manual transmission
- 4.56 vs. 4.88
- how do i install a OEM roof rack on my 4runner
- 'clicking' 4x4
- Turbo Auto to Manual swap questions
- Mystery Electrical problem
- where to mount the arb comp. tank & battery
- Check engine light flashes
- engine source, southern CA
- Ujoint/flanges etc.
- 95 4Runner Distributor Cap Issue
- Head gasket? Getting ready to start.
- HELP recent 22re rebuild wont start, possible EFI issue?
- Power Steering pump 1991 runner?
- need pics of herculined rockers
- Starting problem 1992 Pickup
- 854x4's 22RE Rebuild Thread
- 4runner wont start
- new 4runner, running funky.. ?
- Problem with Vibrating Shaft
- Low Idle stalling 22re
- Torsion bars
- 22RTE Oversized pistons
- Broken Pin in Shift Lever Retainer
- Help! At my wits end - No Spark
- Which header
- Replacing CV shaft c-clip with snap ring
- woooo car accident!
- Fuel pump diy or how-to
- Problem with idle?
- I've got my pinion rotated and cv in the rear for the dual case setup
- 89 4runner with 85 motor?
- herculiner
- 3.0 hg
- Auto tranny shifter very sloppy.
- diagnostic code 10
- Hitch
- need to pull water inlet studs
- cleaning my shifter seat and found strange debris
- manual hub?
- bracket lift installed
- idle surge, rather odd, not answered in any of the threads I searched
- What size cap do I need?
- 94 toyota pickup
- need help 94 toyota pickup
- Post timing chain replacement help needed
- Adjusting LSPV on '87 22R pickup?
- Engine Problems! Help please!
- big fuel leak problems...
- What to do/Pain in but fuel filter
- 22re timing chain replacement
- Engine swap question
- 91 22RE Rebuild- Help Wanted
- 3vze Crank pulley removal
- 3.0 stripped water bypass bolt - doing head gasket
- '86 22re trouble shoot.
- 84 to 88 yota pickup doors
- Marlin Crawler shifter seat and socket.
- A/T oil temp light
- Need some help with my 92 runner
- I think i blew the HG!
- 1986 22re-t can I bypass the turbo?
- I cant get these windows to work help me!!!
- 3vz egr block off
- Need help with a creaking clutch pedal
- Oil Pressure Sending Units
- engine codes 32 and 41
- Timing cover too tall
- Electrically heated mirrors for an '88 truck?
- i want a snorkel
- truck shutters at highway speed
- Where to send my injectors to get cleaned and balanced?
- How to remove the power steering pump?
- gear oil with a locker?
- Small Lift or Leveling kit ?
- sooo...if i were to say...remove my carpeting..
- stock toyota suspension
- Unwelcome 22RE Engine Noise
- toyota atf
- Unique Soft Top
- obd codes
- Brakes Are Touchy...is this normal
- 22RE swap options
- 22RE swap options
- waterproof an alternator?
- Good bye stripes
- Hilux/4runner gears?
- Performance enhancement Chips
- Fan push or pull
- anyone of telling the gears
- ignitor "compatibility"
- Dowl pins in dual transfer case setup / shift rod question
- help!! truck wont start!
- just in case anyone was interested in wiring diagrams...
- cv joint a wiggler
- Opinions: Are A340 Shift Solenoids A Service Item?
- New Badlands bumper, trannie cooler, and lights
- Would a steering gear box 84-90 fit my p/u
- ISR mod and gas mileage
- Who Makes the Best Head Gasket for the 3vze?
- Would 2000 Tundra seats fit a 1987 4Runner
- Sourcing Parts for the 3VZE (3.0 V6)
- u joint
- Lockright Problems
- Adjusting Idle on a '91 Toyota v6 pickup 4wd.
- front diff is leaking from where the cv connects to
- Stainless Steel Brake Lines do not fit on front.
- 3vze No. 2 idler pulley...dropped a socket in it...what now?
- Strange Clicking sound
- 68 toyota pick up carburated floods in 2wd and 4 high
- Adjustible cam gears ?'s
- dumb guy question, or: I hate carburation, etc.
- 3vze timing marks not aligned correctly
- detailing a motor, 22re in an 89.
- any way to seal the carb??
- xtended cab bench vs standard bench
- Idle adjustment 1994 V6
- Rear Crossmembers
- Window track Install
- Driveshaft length for dual transfer cases and TG 5" rear lift
- clunky front end over bumps......
- 22re starting problem
- sick of searching. No body lift for 95 4runner with auto trans??
- four wheel drive NO WORKY! help
- How to set aftermarket speakers from hitting grill?
- Intake sticking out through the hood. Ideas?
- Need help working on my 90 4Runner
- Stock '93 on 33/10.5 BFG any others?
- 2 gen, trail gear rear bumper?
- 22re oil/coolant contamination question
- cab swap question
- A340H Transfer Case Oil Cooler
- W56 Tranny, how do the locking balls go in?
- low idle on 3.0 after warmed up
- no rust and new paint
- Longer valve cover studs?
- Brake Warning Light Question
- i need help!
- coolant temo sensor sheared off
- Front Drive train questions HELP!
- I need advice.....
- Ignition Coil
- 86 4runner: AT problem.... drive seems to be out
- 22RE replacement engine?
- So i finally gave in!
- Removed guages, now turn signals don't work? huh?
- FYI Ignition lock cylinder
- Electric fan wiring
- Thicker Weight Oil stopped Bad chatter and pinging?
- 2wd brake rotor, pad, and wheel bearing question
- Can I fit 36's?
- Metal shaving in rear third?
- 95 4runner door lock problem
- #1 Cylinder Not Firing
- EFI to carb swap
- 3vze engine help TPS?
- ZUK coil mod finished, BJ's installed, pictures.
- knock sensor help please!
- Drivers side power window issue in 91 4 runner sr5 4x4 4door.
- Vacuum/fuel line help
- lost 3 cylinders
- Got the ST2 back home.
- Death wobble
- Head light help
- i need help......desprately
- Tranny go "BOOM!"
- No Radio now storage
- gears
- Update! if anyone remembers me
- Tranny 92 pickup help
- Brakes update and other issues.
- Back in the game/ 3.0 question
- Rebuild or get crate motor?
- Another high idle question after body lift ...I searched! Help please.
- 60/40 bench to buckets question
- transfer case oil seal replacement
- 4wd IS engaging
- difference between sr5 and dlx?
