how much oil in R150F trans?
Old May 31, 2009 | 10:35 PM
yoda84's Avatar
? can i refill my 5 speed trans if i take of the shifter? truck is a 1992 4x4 3.0 5 speed ..... the reason why i ask is because i cant get the fill plug bolt out... with that said i also cant tell if its full so maybe someone knows what the max fill would be im guessing 3 quarts 6 pints....
Old May 31, 2009 | 10:44 PM
904_runner's Avatar
Look in your book.
Sure you can add fluid from the shifter,
Try to get that darn fill plug off though. I always fill it until the fluid runs out the fill plug.
Maybe try some pb blaster, it might help.
abecedarian's Avatar
chart I have says:
W56- 6.4 pts
G58- 8.2 pts
R150F- 6.4 pts
(1 quart= 2 pints)
Old May 31, 2009 | 11:00 PM
yoda84's Avatar
no the fill plug aint coming off trust me i messed it up pretty ugly....um what model would it be or where will it say on the trans.. oh yea i looked in the book it just says 4-7 pints... 1 more thing abecedarian i replaced the coil it runs way better but the idle is still little shaky not bad tho i guess i want it perfect but whatever, i think i got a bad injector so i put some seafoam in the tank see how that goes....
Last edited by waskillywabbit; Jun 1, 2009 at 02:18 PM. Reason: Inappropriate Language removed
Old May 31, 2009 | 11:12 PM
904_runner's Avatar
You may just need to get some good vice grips on it and go from there.
If that doesn't work you can try other "extreme" methods.
Old May 31, 2009 | 11:18 PM
yoda84's Avatar
yea all extreme measures have be taken i used vice grip, impact, weld a socket to it but i suck at welding so, screw driver and hammer, everything now the bolt head is totally screwed so ill just leave it alone before i do more damage but good news i got the drain plug off and it took a impact with 250 psi to loosen it about 4 hits then off it came, if i only could meet the bastard that put it on.........
Old May 31, 2009 | 11:22 PM
toyNG's Avatar
I've had pretty good luck using a chisel and dead blow hammer to get tight plugs to come off. Not sure how helpful that is since it seems like you've already tried something similar. Good luck with getting that thing off, if you're still trying anyways.
Old May 31, 2009 | 11:25 PM
yoda84's Avatar
yea im done with it just trying to figure out what model trans i got so i can match it up with abe's chart.....
Old May 31, 2009 | 11:49 PM
yoda84's Avatar
found it..... http://www.4x4wire.com/toyota/faq/parts/ R150F...... this link might come in handy for someone..
Old Jun 1, 2009 | 11:30 AM
yoda84's Avatar
do you think 6 pints should be good.... i cant tell if im full because my fill plug wont come off...maybe someone kn the correct spec for this...
Old Jun 1, 2009 | 11:35 AM
UKMyers's Avatar
Its in your owners manual and I found it in two seconds with a google search. Didn't anyone ever teach you that you ALWAYS take your fill plug out BEFORE you drain anything in case you can't get it out. How you planning on filling it back up with no fill plug anyways? Gonna tear your shifter apart and pour it in through the top?
Old Jun 1, 2009 | 11:48 AM
yoda84's Avatar
actually i did first try to take it off but no luck, tho drain plug comes off and no its not drained out yet... and the book says 4-7 pints..will try google again
Old Jun 1, 2009 | 11:54 AM
UKMyers's Avatar
Sorry to sound harsh it's just that we see far too many threads started everyday asking for information that is super simple to find. Get you a 6pt socket and a 1/2" drive breaker bar and you should be able to get that bolt loose. My manual does not give anything in pints. It should be 3.2 US quarts. Save this link to your favorites. http://personal.utulsa.edu/~nathan-buchanan/93fsm/ It's the entire factory service manual to a 93 Runner. The info for the drivetrain is the same for Runners and trucks for the most part.
Old Jun 1, 2009 | 11:58 AM
yoda84's Avatar
cool, will keep on lookin sorry...
Old Jun 1, 2009 | 12:03 PM
UKMyers's Avatar
I edited my above post.. the info you need is there now.
Old Jun 1, 2009 | 12:37 PM
neilan's Avatar
Never say you can't get a bolt out. Just say your not smart enough, or dont have the right tools. Take the plug out and fill it up until it runs out.
Old Jun 1, 2009 | 02:35 PM
I could've sworn I posted last night saying the R150F was 6.4 pints, but the thread is gone. And 6.4 pints is 3.2 quarts (2 pints = 1 quart).
Yup I did post. The thread URL is https://www.yotatech.com/forums/f116...-answer-183371 but it's invalid / missing now.
Old Jun 1, 2009 | 02:39 PM
waskillywabbit's Avatar
Read the thread. They were merged.
Old Jun 1, 2009 | 02:44 PM
Oh. okay. When I looked at the thread earlier they weren't. ... Right after he posted https://www.yotatech.com/forums/f116.../#post51152452 I went to look for the other thread and it was gone. Guess it took a while for the system to merge the threads. Then I come back to it now and didn't notice it was twice as long as before.
My apologies.
Old Jun 1, 2009 | 02:49 PM
DeathCougar's Avatar
Maybe you are just too slow Abeypoo The system doesn't lag, its automatic.
