Maintenance/Repair related question...
Old Jun 2, 2009 | 05:54 AM
simpsoap's Avatar
I'm new to the forum but familiar with working on cars/trucks. Had my '95 4Runner in the dealership on Friday to diagnose a small leak in the rear and some noise coming from the front of the truck.
I was told the following needed to be addressed:
- Sway Bar Links Replaced (hole in one of them)
- Rear Pinion Seal leaking
- Rear U-Joint has a lot of play
I've ordered the parts because I enjoy doing the work myself. Question - is there any tricks/tips to replacing these few parts? Anything I should be aware of before I dive in?
TIA!
Andy
Old Jun 2, 2009 | 06:09 AM
4Crawler's Avatar
http://www.4crawler.com/4x4/CheapTri...eal/index.html
Old Jun 3, 2009 | 04:40 AM
simpsoap's Avatar
with the hope of replacing these parts this weekend, can someone tell me if there is a section in the Toyota Manual that explains how to replace the rear U-Joint?
Andy
Old Jun 3, 2009 | 07:11 AM
4Crawler's Avatar
Yes, check the "Propeller Shaft/PR" section.
Old Jun 3, 2009 | 08:14 AM
ozzydg55's Avatar
You tube has some good videos on changing rear u-joints
Old Jun 9, 2009 | 11:39 AM
simpsoap's Avatar
Just wanted to say thanks for the couple of posts I got in regards to replacing the rear pinion seal and rear u-joint. took the time this Saturday and Sunday and replaced both front sway bar links, rear pinion seal and fluid, and rear u-joint.
Andy
zytra
Jan 24, 2019 03:16 PM
rubrsidedwn
Jul 7, 2016 07:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
rmill05
Sep 27, 2015 01:43 PM
