lost 3 cylinders
Old May 23, 2009 | 10:40 AM
krb90's Avatar
lost 3 cylinders
'89 3.0 here...
running on 3 cylinders right now, happened all of a sudden. Cyls 1, 3 and 4 are not firing. So far I've got spark to all 3, and I'm going to do a compression check, even though I'd be surprised to lose compression on 3 at the same time (and on different sides). Going to check the ECM as well. It never overheated. #4 injector connection looks good, can't see 1 or 3.
Going to be away from my computer for a while, but I'm going to check back if anyone has any suggestions......
Old May 23, 2009 | 02:14 PM
krb90's Avatar
update...
got 150-160 psi on all 3 cyls.
traded out an ECM from a '90 3.0, and no difference.
So, in short, I have 3 dead cylinders. All 3 have compression. All 3 have spark. That leaves fuel...so what would cause 3 injectors to go out at once, 2 on one side and 1 on the other? (assuming it is injectors, thats about all thats left, right?)
Is there a rev limiter? If so, where is it? And is that something that would "freeze up" or something? I am out of ideas, other than start tearing stuff apart.
Old May 23, 2009 | 03:02 PM
874runnersr5's Avatar
Yeah injectors seem like a idea to check
Old May 23, 2009 | 03:06 PM
abecedarian's Avatar
I'd lean at a wiring issue.
Old May 23, 2009 | 03:15 PM
A loose injector wire
Old May 23, 2009 | 03:21 PM
DupermanDave's Avatar
I'd also say it's a wiring problem.
Old May 23, 2009 | 06:03 PM
Lummpus's Avatar
x3 on the wiring. Look at your FSM and see what those 3 cylinders have in common.
Old May 24, 2009 | 09:46 AM
krb90's Avatar
I did, but other than the ECM, I don't know what they have in common. So I guess I'll start taking things apart.
4.34runner88
Feb 7, 2016 02:24 AM
calderp
Nov 16, 2015 02:49 AM
TOYOTASC
Sep 10, 2015 05:18 PM
old87yota
Sep 9, 2015 12:39 PM
Squigglez
Sep 4, 2015 07:33 AM
