89 4runner with 85 motor?
Old May 28, 2009 | 01:01 PM
Kazsunam's Avatar
I have a rolled 85 4runner and am looking into putting a 89 tub on it. I live in California and I don't know if it would pass smog as an 89 with a 85 motor. Anyone know anything about this? Thanx.
Old May 30, 2009 | 06:28 AM
FredTJ's Avatar
Just check with the CA Dept of Motor Vehicles and see what they say.
That would be the most reliable source of information, don't you think
Fred
Old May 30, 2009 | 08:46 AM
DeathCougar's Avatar
You can swap the motors no problem. However, just swap the long block. Reuse all the wiring, injectors, sensors, intake, and anything else from YOUR truck on the NEW motor. Just swap the long blocks ONLY. It is completely legal as long as its a like type engine, and toyota used the same 22RE long block from 85-95.
DO NOT Try to swap the entire assy with wiring and sensors over. IT WILL NOT WORK CORRECTLY!
Old May 30, 2009 | 08:50 AM
algranger's Avatar
There is a lot of little things that changed through the years but essentially the motor is the same, just use the old emissions stuff, computers, etc. and you should be fine
Old May 30, 2009 | 08:51 AM
algranger's Avatar
Long block is the earlier model isnt it?
Old May 30, 2009 | 09:03 AM
TOYOTA 1's Avatar
no thats the tall block.. long block just means heads/block assembled.
Old May 30, 2009 | 09:08 AM
abecedarian's Avatar
"Long block" is a generic term which refers to the engine block and cylinder head assembly. You're probably thinking "tall deck" or similar.
Anyhow... with regards to putting an 89 body on an 85 frame, my advice is to contact the DMV and ask what's necessary as they will have to be involved in re-assigning the VIN numbers since the 85 VIN would no longer be on its chassis.
Old May 30, 2009 | 09:35 AM
hmm, I didn't get that he was swapping bodies.
In that case, just scrub off the old VIN's and call it good
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
AaronM
Jul 8, 2015 07:15 PM
karbin
Jul 5, 2015 11:37 PM
