22re starting problem
Old May 25, 2009 | 03:22 AM
jdshiver's Avatar
Hi all, I have a 89 pu w/22re. Wont start turns over fine just wont fire up. I pull the efi fuse and put it back and it starts fine about 2 or 3 times then wont start. Just rebuilt 500 mi ago started fine now having problems. any ideas?
Old May 25, 2009 | 12:50 PM
bugs1961's Avatar
I have a '94 Camry that had this same problem a few years ago. The fuse slot in the fuse block got loose and the fuse would make intermittent contact. I bent the fuse spades into a slight "v" shape to make it fit tight in the slot and have had no problems since. When the car wouldn't start, the "check engine" light wasn't coming on either since there wasn't power to the ECU. Take a look and see if your light comes on when you turn the key to the ON position.
Old May 25, 2009 | 02:25 PM
jdshiver's Avatar
Thanks I will check it. I will tell you if this works.
Old May 25, 2009 | 04:40 PM
jdshiver's Avatar
Angry
wasnt the fuse. still having the same problem.
Old Jul 28, 2009 | 01:12 PM
jdshiver's Avatar
Ok I fixed it. I unplugged the computer cleaned male and female connectors plugged it back in. Has started fine for a month and a half.
Crazychris1871
Jun 27, 2016 10:38 AM
jennygirl
Nov 17, 2015 11:24 AM
Ichneumon
Sep 27, 2015 04:21 PM
Sandman
Jul 23, 2015 08:15 PM
Old Red 94
Jun 16, 2015 08:32 PM
