gears
Old May 22, 2009 | 05:09 PM
jokers052005's Avatar
gears
i just recently got a hold of an 87 toyota pickup and my timing is idling really high and my gears are really low. i cant figure out why my timing is so high and i plan to have my gears re done. what do yall think i should switch my gears to. i need the truck as a work truck as well as a truck i can take to play in the mud on some occasions. the engine i have in my truck is a 22r.
Old May 22, 2009 | 05:43 PM
NicCantDecide's Avatar
Usually I'd tell you to search, but you don't really seem to know much about engines so this time I'll tell you to go get your truck tuned up and also do a search on regearing.
Old May 22, 2009 | 05:46 PM
DupermanDave's Avatar
Definitely search. There's only about 2 gear ratios people recommend.
There's a thread about gears created every week. There's enough answers out there already.
4.88 seems to be a standard ratio people recommend.
Old May 22, 2009 | 05:50 PM
dropzone's Avatar
Fossilized
gear size is relative to tire size and if it's an auto or a stick
Get the truck running correctly first
4.88's = 33" tires
5.29's for 35" tires are the usual recommendations.
If this is a work truck with a rack, i would not go higher than 33" tires.
see the FSM link in my signature, you should find the correct manual you need or just pick up a timing light, tune up stuff (plugs, wires, cap, rotor) and a chilton's and have a fun weekend.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
