driveline or pinion
Old Jun 2, 2009 | 11:24 AM
my fingerz hurt's Avatar
driveline or pinion
i have a 3rd gen sas toyota 6 in lift, 4.88 gears, 37" toyo mt, and i finally got the truck running again. it has sat for a little under two years and got enough money to get it going. my problem is when i take off in 1st it has a bad vibration from the rear, then go to 2nd and goes away, but once it reaches 55 there's sort of a pulsation coming from the rear...could it be the u joints in the drive line went bad? i checked the pinion and there's no play front to back so its not loose and the gears seem to engage fine...and how much play turning the pinion should there be?
Old Jun 2, 2009 | 01:05 PM
space-junk's Avatar
first off, check the u-joints for play... if so, then thats where your problem is, and im willing to bet thats the problem... mine does the same thing...
as for the rear end, if it WERE going out, then most likely it would be producing a whining/grinding sound (zuk calls it "singing") coming from the rear but there wont be any "vibrations" so to speak...
Old Jun 2, 2009 | 05:53 PM
turns out it was the ring gear was f'd up because the pinion was set to close to the carrier...anyone know how to adjust that?
Old Jun 2, 2009 | 06:39 PM
yoterr's Avatar
uhhhhh take apart and put shims behind it kinda a pain in the A$$
Old Jun 2, 2009 | 06:58 PM
TOYOTA 1's Avatar
uhh if its to close he would want to take some out
read abunch here, http://www.gearinstalls.com/
kawazx636
Oct 6, 2021 03:03 PM
ktm192k
Oct 1, 2015 08:47 AM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
justdifferentials
Sep 5, 2015 06:52 PM
