Need help with a creaking clutch pedal
Old May 27, 2009 | 10:38 AM
Fo by Fo's Avatar
So my 91 4runner's clutch pedal is starting to creek or creak (however you spell it lol) when the pedal is pushed down. I replaced the clutch bracket a few months ago and I don't see a crack in it so I think that is good. When the bracket cracked the mounting point in the upper dash was ripped out so I pop riveted in a piece of metal to hold it there. I hope to god that is holding up. From what I have read it sounds like it could be a bad bushing. Does anyone know where I could find a write up on this or pics of what it is suppose to look like with the bushing? I don't see one around the pin but I don't remember there ever being one there. Do I possibly need to oil something?
Old May 27, 2009 | 10:45 AM
abecedarian's Avatar
what about the return spring?
Old May 27, 2009 | 10:55 AM
Fo by Fo's Avatar
What about it? Do you mean have I checked or oiled it? Is the return spring the one that is clearly visible above the clutch pedal?
Old May 27, 2009 | 11:02 AM
That would be the one. It pulls the pedal back up when you release it. Springs creak sometimes, particularly if something causes binding or makes it vibrate. If it is the source of the noise, oiling it might temporarily stop the noise. Sliding a piece of vinyl tubing that is slightly tight over the spring can also help dampen noise.
Old May 27, 2009 | 11:48 AM
Fo by Fo's Avatar
Where do you oil it? What do you use to oil it?
Old May 27, 2009 | 11:57 AM
894x4pickup's Avatar
Just spread some grease over it, stretch it out and apply a thin layer...oil will drip all over...Oh, and also when mine was squeaky i took of the whole pedal and greased the bolt and both sides of the plastic sleeve inside...
mxdw88
Sep 20, 2015 03:13 AM
scheuvront1993
Sep 17, 2015 06:17 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
Squigglez
Sep 4, 2015 07:33 AM
