'86 22re trouble shoot.
Old May 27, 2009 | 05:05 PM
thecaper's Avatar
'86 22re put it in about three weeks ago, I suspect I'm getting fuel in my oil... again. So, what I'm looking for are some pictures or input on which vaccume/fuel lines might be the cause of this issue, (fuel in oil), The compression is reading about 155 on all four so I don't think rings are the problem.
What are your thoughts?
Old May 27, 2009 | 06:19 PM
yoterr's Avatar
kinda awkward to say the least....but try searching around here on the forum and if nothing turnes up try ur fsm and track down some hoses!!
Old May 31, 2010 | 06:56 AM
Tewubique's Avatar
1990 22RE - whereabouts on the body is the fuel pressure regulator?
My son took the fuel line off and I cannot find where it came from!
The fuel line that comes up from the body on the passenger side of the engine, what direction does it take, and where does it go?
Thanks for your help
Old May 31, 2010 | 08:37 AM
PismoJoe's Avatar
FSM....
http://www.ncttora.com/fsm/index.html
Old May 31, 2010 | 08:42 AM
4Crawler's Avatar
Under intake next to firewall:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
Old May 31, 2010 | 03:36 PM
yayfortrees's Avatar
The only way I can imagine fuel entering the motor, besides the way it's supposed to, is by somehow getting through a charcoal canister and up into the valve cover. I don't even know if lines are connected that way, probably not.
Usually, the fuel tank will be vented through a charcoal canister. Sometimes, a crankcase breather will also be vented into the charcoal canister, although I think on these trucks they are vented into the airbox.
I don't really know, this is a very odd problem. What makes you think this is happening?
Old May 31, 2010 | 07:26 PM
4x4jeffyota's Avatar
piston rings are prolly bad
mskalmus
May 28, 2017 07:51 AM
skoob
Oct 15, 2015 03:23 PM
mtc1105
Aug 4, 2015 08:06 PM
defrag4
Jul 31, 2015 10:50 AM
