steering wheel still shakes after frontend work
Old Jun 1, 2009 | 07:19 PM
dem0nk1d's Avatar
im still getting a pretty good amount of shaking in the steering wheel.
i've replaced the following parts
1.pitman arm.
2.idler arm.
3.steering stablizer/shock.
this fixed alot of my inital steering wheel vibration but i still have some, and don't think it's normal. what else or where else should i look.
balljoints? tie rod ends?
wheel bearings....
Old Jun 1, 2009 | 07:21 PM
yoda84's Avatar
unbalanced tires.....
Old Jun 1, 2009 | 07:48 PM
dem0nk1d's Avatar
i will head to this shop and have my tires balanced, but i recently had the driver front balanced because i knew for a fact the weight wasn't on the rim
Old Jun 1, 2009 | 07:51 PM
abecedarian's Avatar
warped rotors, incorrect caster, bent rim, out-of-round tire(s), cat/dog/jeep stuck in tread
Old Jun 1, 2009 | 07:54 PM
dropzone's Avatar
Fossilized
post the results of your front end alignment, they should have given you a print out....alignment done right
Old Jun 1, 2009 | 07:59 PM
dem0nk1d's Avatar
when i replaced all the parts i got the front aligned the guy said everything was spot on. i don't think i have the printouts... errr.. i wouldn't think it was a warped rotor, that would only cause shaking when stopping.
so the only things i can think of is replacing the tie rod ends, and balljoints before i take my truck to toyota to get the steeringrods replaced because of the recall. this will give me a free alignment. =) lol
might as well use the recall to my advantage.
Old Jun 1, 2009 | 08:17 PM
dropzone's Avatar
Fossilized
free alignment at the dealer...very cool, smart man
hope you get the gremlins solved...it can be a PITA chasing them buggers sometimes
Old Jun 1, 2009 | 08:21 PM
Fink's Avatar
Start with the simplest thing first - alignment + balance.
Let us know what happens.
Fink
GreenLion
Jun 7, 2021 10:49 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
Hermes
7
Jul 8, 2002 03:45 PM
HBoss
Jun 29, 2002 12:14 PM
BTOWN4RUNNER
Jun 16, 2002 06:08 PM
