Ignition Coil
Old May 24, 2009 | 08:56 AM
first_toyo_owner's Avatar
Ignition Coil
Hello It seems that i may need an ignition coil for my 90 sr5 2.4l 22re 4runner but i am looking online and i can't seem to find the actual coil I need. Hopefully I am talking about the right thing here. The igniter i believe is this.
http://cpwstore.carpartswholesale.co...L/A358140.html or one a little different depending on make or model, now I am looking for the plugs themselves as appose to just that. I checked lordco and they said 500 bucks for one. Is there anywhere cheaper that i could get one. Does anyone have links for me or even one they can sell me would be appreciated thanks!
Old May 24, 2009 | 09:20 AM
so the part number i think i need for the coil with igniter is 19070-35210 K x also there is another pt number 101311-54580 anyone help?
Old May 24, 2009 | 10:33 AM
iamsuperbleeder's Avatar
nah, a replacement coil, OEM style from any local parts store, shouldn't run you more than $20-$30, if that IS all that you need
the ignitor is the black box-lke thing mounted above the round coil, and THAT'S what is going to carry a heafty price for a new replacement
You might want to check a junk yard first; they tend to not go out too often, so chances are you would pick a replacement for the same price as a new coil from the parts store, IF that is you problem in the end
what leads you to think either is bad?
Old May 24, 2009 | 10:35 AM
toyospearo's Avatar
I HAVE ONE
Its sitting right here... https://www.yotatech.com/forums/f107...oodies-181564/
its yours for $50.00
came off an 83 22r
Old May 24, 2009 | 10:42 AM
Originally Posted by toyospearo
I HAVE ONE
came off an 83 22r
the coil maybe, but I believe the ignitor from an 83 would be a bit different from one on a 90, iirc
Old May 24, 2009 | 10:53 AM
toyospearo's Avatar
let me know!!
I have two of them
D
Old May 24, 2009 | 08:10 PM
its the wrong one i have that igniter already
Old May 24, 2009 | 08:33 PM
toyospearo's Avatar
ok!
good luck with it!
Old May 25, 2009 | 05:16 AM
well we checked the igniter and the distributer and spark plug and connected the igniter coil directly to the battery and it still didn't fire
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
voiddweller
Sep 28, 2015 11:21 PM
mojo4x420
Sep 16, 2015 08:07 AM
JHalcyonM
Sep 14, 2015 01:10 AM
