PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Embarrassing Story... I need help
  2. Supercharged 5VZ Swap to 91 pickup
  3. Anyone with POR 15 regrets?
  4. You might know someone?
  5. Receiving Hitch for 86 4Runner
  6. What does this connector / sensor do ?
  7. Power steering shaft leaking
  8. Seperating hub from rotor?
  9. 4 runner dies out of nowhere when driving
  10. Runs better with vafm unplugged
  11. 1994 Pickup signal and emergency lights
  12. Blown head gasket?
  13. Help needed in getting 22re engine manual
  14. 1986 22r Turbo Called Old Yeller
  15. Tonka Toy Build
  16. Help! Brake booster or brake booster check valve?
  17. Replaced both control arm bushings at same time - truck drops to the ground.
  18. 1994 4Runner rear window fix
  19. R150 counter shaft C-clip
  20. No start
  21. On the side of the road again
  22. Loose parking pull brake. (new member)
  23. Is this a head gasket leak? (with pics)
  24. 86 solid axle 4runner
  25. help 2nd gen 4runner clunking noise
  26. Crank, fail to start '87 4runner.....
  27. Issues caused by missing gas cap?
  28. Give up, need help 93 pickup 22re 2wd
  29. 1994 Toyota Pick 22RE Automatic 2 wheel drive
  30. ARE DCU on a Toyota Pickup
  31. 94 4runner stalls over bumps
  32. 3vze iacv gasket
  33. Help identify hoses
  34. 2nd gen 4runner front license plate mounting
  35. 1995 V6 3.0 SR5 Cluster Swap Tach not working
  36. Home made cup holder
  37. Cruise Control wiper switch versus no CC or intermittent wiper
  38. Lost key/pulled ignition lock cylinder/broken ignition?
  39. Power steering leak from rack?
  40. 2nd gen mud flaps?
  41. High pitched noise coming from steering collum/dashboard area
  42. 1990 22re pickup drum brakes adjustment ?
  43. Looking for this kind of grille
  44. 22re Acting Weird
  45. Weird Door Lock Issue
  46. Auto to manual swap problems
  47. 1989 4Runner Front end and more
  48. No start with spark and fuel pressure
  49. 22re Code 5 - help!
  50. Loose radiator cap?
  51. 92 3VZE has spark, won't start. 80A fuze blown.
  52. Starter trigger wire
  53. 91 Long body transmission
  54. Another cold start issue
  55. A/C problem
  56. A/C dilemma
  57. Outside Door Handle rod - 89 Pickup 22RE
  58. Sway bar end links suspension improvement?
  59. 22rte to a 22re
  60. 1986 Pickup detent/kickdown cable - will 88 fit?
  61. I need some opinions guys.
  62. Cab Over Camper
  63. 1994 Heater core bad?
  64. 1993 Toyota Pickup Suspension Help!
  65. 95 3vze
  66. Frame Repaint/repair
  67. Cup holders
  68. 92 4runner New Shock Suggestions
  69. Engine 22re cylinder head removal (wires)
  70. journey of a broken stud
  71. 1986 Toyota Pickup - OME CS009R springs with Bilstein 4600 shocks?
  72. HELP! 94 TOYOYA pickup *VIBRATION* @ idle
  73. Help! Bad oil leak. 90' 3vze
  74. Order Of Operation of setting New Suspension
  75. Mysterious valvetrain noise
  76. 86 22RE Build up/ What could that sound be?
  77. Facebook
  78. Compression
  79. PS union bolt
  80. stainless steel exhaust hardware
  81. parts diagram database
  82. 22RE Throttle body shaft seals / rebuild
  83. Internal engine issue.
  84. Fueling issues
  85. Clutch master
  86. Roof rack for 91 4Runner
  87. Delete IACV and add high idle switch
  88. EGR seeping oil
  89. Front Spindle Bushing
  90. Total Loss-1992 Toyota Pickup 4 Cyl PU
  91. 22R Timing chain rattle on freeway drives
  92. Is this thing supposed to move?
  93. 89 4Runner - Need Wiper Help
  94. Install Question - Bilstein 4600 Front 2WD
  95. Difficult idle at stop lights
  96. Rear main seal
  97. '89-'95 Factory AC Condenser Fan
  98. 87 CV/Knuckles seal questions.
  99. rebuilt my 22re cranks wont start no codes
  100. 2wd headers for 3.0
  101. Nerf Bars - Where to Buy
  102. How do you deal with stripped plastic threads?
  103. whether to replace muffler?
  104. 1990 3VZE engine into 1995 pickup...ecu,harness,speedo adivce needed
  105. Needing help again
  106. Addicted Offroad, Refunds Money Without Asking
  107. 22re swapping for 22r please help!!
  108. my first 3vz toy with many problems
  109. fumes from pb blaster
  110. Short??? Haz/Horn circuit 87 22re 4Skinner
  111. HUB: Normal or replace??
  112. New clutch shifting into revers issue
  113. broken exhaust pipe
  114. What to replace on an engine install?
  115. 3vze timing belt/water pump kit - Auto vs Manual
  116. Please help in SD
  117. Please help in SD
  118. Replace starter on 87 PU auto
  119. Rubber Body Bushings
  120. Need ideas/advice
  121. CraigsList 4Runners
  122. Need help. Pop from rear end and wouldn't move
  123. Rubbing sound then clunk???
  124. need help w/ clutch year
  125. Continued Idle Issues
  126. Stipe kits?
  127. First time partial resto paint...
  128. US vs Japanese Trucks
  129. 87 4x4 pickup 22R carb
  130. 87 4x4 pickup 22R carb
  131. Fan Clutch Oil
  132. 22R 87 Pickup Gas in Oil
  133. OE Radiator part #
  134. 1990 4runner 4x4 new gas tank needed.
  135. 1991 pickup
  136. Rough idle/misfire Issue
  137. 1994 Toyota 4runner 3vze v6(hose under fpr and it's vacuum sensing hose)
  138. Burning A LOT of oil
  139. A43D transmission 2wd prerunner
  140. Getting shocked
  141. 2nd gen OEM e-Locker?
  142. Chassis advice
  143. Trouble retrieving error codes - 92 22RE
  144. Blinking overdrive light?
  145. help with opinions
  146. 3vze help!!!
  147. 3vze - replacing cam seals without taking off crank pulley..??
  148. This code 25 is very different. Anyone?
  149. Shocks shocks shocks
  150. Official end of V6 head gasket SSC
  151. Denso fuel pump recall?
  152. REAR ANTI LOCK light saga
  153. Installing sound system
  154. '89 Hilux 3.0 - hunting idle
  155. 1985-1995 Toyota 22R and 22RE Cylinder Head Differences
  156. 22R replaced with remanufactured and can’t get it to idle
  157. Tune up time 1990 single cab 4x4 22RE
  158. Problem with 1987 AT
  159. Idle Issue
  160. 95 3vze no power to injectors and fuel pump?
  161. Took the windshield out and the truck came with it...
  162. Toyota 3vze idles but runs extremely rich
  163. 3VZE won't stay at operating temp
  164. Electric fan controller
  165. 3Vze vacuum line help
  166. exhaust leaks between O2 sensor gasket and pipe
  167. Needing help
  168. 95 4R tailgate window switch
  169. 1990 4Runner Auto transmission wont go into gear and wont turn on
  170. 87 turbo 4Runner cranks, dies
  171. 87 turbo 4Runner cranks, dies
  172. 1990 toyota pickup V6 3.0 2wd motor mounts
  173. Idle Air Control Valve (IACV) - Genuine or Aftermarket?
  174. Vacuum line rail replacement...3.0
  175. Decision crate engine vs ???
  176. 1995 4Runner CEL 71 (EGR) help needed
  177. 2nd gen 4runner, No spark
  178. Gasket / RTV / FIGP Question
  179. Mystery loose wire? Uh oh...
  180. Rehabbing advice 1991 4WD
  181. Blown head gasket, but good compression and block test results? Or bad radiator?
  182. looking for a selling price
  183. 89 clutch pedal bracket fix ​​​​​​​
  184. 3VZE rear main seal RETAINER leak?
  185. 94 4runner fuel cut on acceleration
  186. Body/mount broken
  187. 1987 front heater core repl. 22RE
  188. 7.5" w/ truetrac fitment issues...
  189. Clutch occasionally slipping
  190. 88 4runner rear defogger
  191. 92 2WD Drivers Upper Control Arm
  192. Turn Signal Parking Light Swap
  193. heater supply hose
  194. Vent Window Hardware?
  195. '93 Treuck 4 WD Fuel tank access
  196. '93 V6 has no fuel
  197. Suspension Guru's - Spring ID help needed
  198. 22R Coolant in Oil, Help!
  199. Oil analysis results
  200. Carb swap over efi
  201. Timing Chain & Cover Replacement
  202. Dashboard rebuild
  203. New fenders
  204. 1990 pickup rear diff upgrade
  205. Pretty Funny and Cool! The Torqamp electric Turbo!
  206. Hard bounce on suspension
  207. 1994 Toyota pick up 2.4 22re w55.
  208. Idle air contrive valve troubles
  209. Largest tires on a 86 2x4? Last year of the long beds in the '90s?
  210. 1986 4Runner dies after warmed up
  211. 86 PU Water leak drivers side ??
  212. Are Toyota Hilux and Toyota Pickup seals the same?
  213. First Timer Starter System Question ‘87 4x4 22re auto
  214. rusty fuel tank, odd thing inside.
  215. Radiator material opinions
  216. Speedo cable, steel sheath
  217. Electrical Problems 89 Toyota P/U
  218. Minimal spark
  219. 1990 toyota pickup charge issues
  220. 94 rear speaker wire pinout
  221. transmission transfer adapter output/transfer case input leak?
  222. Intermittent Solenoid Problem
  223. At my witts end - electrical gremlins??
  224. Remove and replace fuel pressure regulator 3vze
  225. Need new 1994 3vze auxiliary air control valve gasket
  226. Washer fluid nozzle replacement/upgrade
  227. Headlights suggestion
  228. Gurgling sound and leaky firewall
  229. 89 pickup 4x4 pinion seal
  230. 1988 Runner 3.0L Automatic to Manual Conversion
  231. One thing we All have in common...
  232. 1990 Toyota 4runner wont shift into 4WD
  233. My truck runs a few seconds and then quits ...
  234. ifs front with spartan locker and selectable ADD?
  235. 1992 Toyota Pickup 4 Cyl PU
  236. What are these 5 hoses called
  237. 1988 TP 22re efi 4x4 loss of power/hesitation
  238. Parasitic drain/12 volts on ground cable
  239. Dashboard lighting
  240. 94 4runner sr5 brake issues
  241. RF1A Transfer Case Noise
  242. Block heater
  243. I have 92 4 runner need help
  244. Transmission mount: OEM or brick and mortar aftermarket?
  245. Where can I buy new window seals for the Xtra cab small rear glass?
  246. 91 4Runner: no gauges, no fan,
  247. Alternator question
  248. Clutch Swap and Oil pan question?
  249. OD light flashing
  250. transmission/transfer case fluid mixing
