Help identify hoses
Old Apr 4, 2021 | 08:32 AM
Shooterfriendly's Avatar
Help identify hoses
95 4 runner 3.0. Cant figure these out. Both hoses that connect to the metal elbow.
Need to replace these hoses. Cant find them in repair book.
This one starts at the back end of throttle body and winds up here.
Old Apr 4, 2021 | 09:26 AM
scope103's Avatar
Welcome to YotaTech. Is this an Escalade?
Seriously: if you went to a parts store and pulled out two photos, what is the first thing they would ask? Make/Model/Year/Engine/Transmission/Trim.
Okay, it looks like a Toyota 3VZE, but what year? What model (truck, 4runner, etc.)?
Take a look at these two pages:
https://parts.lakelandtoyota.com/sho...rimLevel=18380
https://parts.lakelandtoyota.com/sho...ukey_make=1060
Old Apr 4, 2021 | 11:14 AM
yeah, sorry about that. It’s the
second time I tried posting this and forgot the second time around. 95 4Runner 3.0.
Old Apr 4, 2021 | 08:00 PM
2ToyGuy's Avatar
Top picture, I believe, is the return from the heater. That's the heater control valve, just touching the bottom of your red oval. It controls the amount of hot water from the th engine's cooling system into the front heater. The hose you circled is the return hose from the heater core back to the cooling system.
The hose in the bottom picture is the water feed to the throttle body. Makes the air going in warm up faster, and prevents cold, cold air going into the throttle body from causing icing.
From the FSM, how to take off the throttle body:
Does this help at all? I don't have part numbers right off, but they shouldn't be that hard to find...
Pat☺
Old Apr 4, 2021 | 09:33 PM
Thanks. That should help. I got to take off throttle body for that hose?!
Old Apr 5, 2021 | 07:00 AM
Jimkola's Avatar
YT Community Team
5 Year Member
see them here?
Old Apr 5, 2021 | 08:40 AM
scope103's Avatar
The parts are called out on these two pages. (the heater hose is in "heating," the hose under the throttle body is in "cooling.") Along with the part numbers, the price (from the dealer in Lakeland FL), and a way to order them from Lakeland if that's what you choose.)
Disconnecting the two hoses under the throttle body is part of removing the plenum. For me, I have to loosen the plenum to lift it about 2-3cm to get enough room to disconnect the hoses. You might be able to disconnect the throttle body without moving the plenum, and then lift just the throttle body to get to the hoses. I've never had any need to do that.
Old Apr 14, 2021 | 11:38 PM
Pat☺
Thanks, that is helpful
coopster
Feb 13, 2021 11:17 AM
LUKETHEGOAT
Sep 24, 2020 11:35 AM
Swank
Jan 29, 2013 03:05 PM
86toysr5
Oct 10, 2007 07:17 PM
