Remove and replace fuel pressure regulator 3vze
Old Feb 3, 2021 | 06:04 PM
Tech92420's Avatar
Does anybody know of any way to take out the fuel pressure regulator without removing the plenum? I really don’t want to remove it and open a can of worms.
Old Feb 4, 2021 | 08:08 PM
scope103's Avatar
Nope, can't do it. You have to lift the plenum a little so that the FPR can make a complete turn.
But ... why? FPRs do fail, but not often. Why are you replacing yours? And why do you have worms under your plenum?
Old Feb 4, 2021 | 10:47 PM
Tech92420's Avatar
I had a rich code, code 26. My 02 sensors were graphing properly on a scope. I applied vacuum to the FPR and it wouldn’t hold vacuum and my hand pump smelled like gas. Luckily I went to tear into it and wouldn’t you know? My dad, the previous owner, ground the corner of the manifold that was in the way of the FPR. He claims he replaced it over 20 years ago. I was happy about that because it only took like 10 minutes to do. The part that is ground down is covered by the bracket for the throttle cables. It’s not noticeable and the manifold still works. I guess it’s not stupid if it works.
Old Feb 5, 2021 | 04:06 AM
87-4runner's Avatar
Well played by your pops... let us know if the FPR fixes your issues.
Old Feb 8, 2021 | 06:55 PM
Tech92420's Avatar
FPR did fix code 26
After I replaced the FPR got a code 25, lean condition. Well I was a dumbass and I didn’t have the right side of the VAFM connector seated right. The wire popped off when I plugged it back in. Put about 100 miles on it since. My fuel economy increased and now I don’t have that check engine light coming back on.
Old Sep 19, 2021 | 04:29 AM
Phear's Avatar
5 Year Member
This might help some one in the future too. I put a small screw driver in the end of the fuel stub of the FPR and bent it so that it cleared. Went on just fine, then bent it back down.
mr.c68
Mar 25, 2024 09:44 PM
ThomasJ
Aug 7, 2014 10:39 AM
jastamjas
Aug 28, 2012 05:22 AM
