- EFI turbo?
- EVAP Canister on older P/U
- 87 toy vacuum advance
- cruise and turn signal??????????
- ARP (cylinder head) Stud Questions
- found on craigslist
- snorkel and cyclone install
- brake issues
- Should I buy this 89 4Runner?
- Bleeding brakes w/proportional valve
- Will a 89 4runner 3.0 auto tow 2500# pretty good?
- Couple of questions
- engine turns off when turning, other issues
- Rear Diff Rebuild Questions.
- Provin Trail Set-up
- Clutch master/slave bleeder screw
- A/C fan for extra cooling
- transfer case e-brake (V6) questions
- Puck Lift
- turn wheel and not so good sounding noise happens
- Another CV Boot Thread
- 1995 Toyota Tacoma driver Door Issues
- stock stereo
- Rear coil springs for trailer towing
- 1989 Toyota pickup 22r distributor help
- 2" Lift Kit
- My on-going brake problem is plaguing me.
- 86 toyota pickup prerunner conversion
- swapping different year cabs on 2wd truck??
- Advice needed.
- my clutch is acting up...
- CV axles swap
- I need your guys' opinions......
- 95 4Runner - What part of the year produced???
- 3.0 Issue....
- opinions
- Need the yota tech gurus... Please
- NGK G-Power sparkplugs BKR5EGP
- power window relay part number
- Got my gears put in.
- clang (or clunk if you prefer) coming from Driver side wheel?
- tranny flexplate install advice
- My truck is clunkink
- Int wiper motor needed for int wipers?
- Help with 3VZE ignition timing
- Auto Radiator into Manual truck?
- still grinding
- any step-by-step websites?
- i need help!!!!!!!!
- Cap/Rotor Recommendations/Experiences??
- forgot to unlock one hub...any risks?
- T-case Regear
- Exhaust pipe issues
- Which locker for REAR?
- please help im crying here!!!!!!!!!!!!!!!!!
- Clear lake customs SAS Build
- 22re- shaving head 20 thou. for compression
- Bad clutch cause Head gasket to fail??
- 22RE valve cover question
- junk?
- spare tire question!
- Fuel Injectors ?.
- 1988 std cab with clunking noise in 4x4
- radiator issues on 22re, sign of something bigger?
- 1st Gen Soft Top
- Gauge and dash backlighting
- Do I need new fuel injectors?
- exhaust stud vs. bolt question
- Covering a Topless 4runner
- Dumb Question
- Removing the Belt/Clutch Fan
- 94 pickup gearing
- jacobs electronic ignition
- IFS removal. Is it really that easy?
- Cam question
- Has anyone tried this motor?
- could retarded timing kill a knock sensor
- '95 SR5 3.0L rough idle, rear brake light issues
- truck just started puffing blue smoke
- Finally! Painted the toyota. Step by step pics. 56K no no.
- $1000 (PLZ no drama lamas)
- Thinking about doing a A/C conversion.
- w56 question
- chevy spring swap question
- Still Not Right
- Rear Suspension Setup
- Front bodymounts - vertical bolts - what tap?
- How often do dataplates get messed up?
- Fuel system Woes
- frame restore - just getting started
- draining coolant
- 4Runner Speakers
- 4.30 ring and pinion
- using 80s 22re manifold on late 22re
- 91 p-up manual hub conversion
- 1.5"....Which springs to get?? Which shocks??
- Looking for a smoother ride
- Just replaced head gasket on my 3vze and now water is coming out of the back
- Need a wiring diagram for a 1995 4runner
- Nashua Toyota Mechanic
- Rides like poo poo..
- 94 4Runner Power brake problem
- Denver Colorado Mechanic?
- 3.4 swap questions
- Low beams will shut off while driving at night!!
- 3vze oil temp
- High Idle-Help!
- What $600 can do!
- Big problem
- tranny fluid
- Maybe: The Craziest Question Ever On Yt>>>
- 22RE air intake hose missing??
- Custom body damage courtesy of Mr. Tree-pics inside
- Locker installed
- Fire Extinguisher mounting?
- 93 Pickup Lagging/Slipping/Oil Problems???
- 1991 Toyota x-cab sr5 4x4 Black Smoke
- 22re runs different after gasket replacement
- kinda a dumb question
- What vehicles and years used the same carburetor as in my 86 pickup?
- fender flare question
- lighting for snow
- Problems after exhaust manifold gasket R&R
- What is the average price to get the 3VZE Heads machined
- Need a 22re rebuild...any recommendations?
- Squeezing the life out of an engine on it way out?
- weak 87 yota
- distributor rotor
- Really STUPID question, but I have to ask
- Its apart now what?????????????
- where did you guys get your new u bolts when adding blocks???!!
- CODE 51, anyone have any ideas?
- charge light and brake light????
- Trans and engine stuck
- 22R-E new oil pump. Where do I go for oil pressure?
- Manual doors to electric
- warn m8000 model number
- My first yota, fan clutch, shocks, lighting
- ok heres a question v6
- weak blower motor
- Low Oil Pressure?
- 22R won't run after rebuild
- OK GUY it is TIME to HELP the IDIOT>>>>> READY?
- how do u take out the pilot bearing?
- Truck misfiring, stumbling
- trouble removing crankshaft pulley bolt
- Okay folks ITS time to tear it out.
- Starter relay...again
- Could use a bit of advice 3VZE motor removal
- need tilt steering assembly for 84 2wd
- What seal packing (gasket material) do you prefer
- 95' v6 engine swap advice
- 3.0 rebuild parts list
- rear springs
- squeeling tires while turning
- 22RE turbo'd on propane...MSD ignition ?
- 86 power steering box adjustment screw
- power steering gear box adjustment screw
- Bear with me here!
- AC Push Button Switch Changable?
- Newbie replaced Head Gasket, Truck wont start...
- engine hesitates...
- intermitent hesitation?
- Ball joint spacers again
- emergency 4runner engine problem
- Where is the "starter / ignition relay"? Could use some gifted help here!
- Lspv
- Celica Vs. Truck -- 22RE FI Differences?
- knocking front wheel (Driv. Side)
- 1988 3.0 rebuild
- CV Boot Tear and Manual Hubs?
- Back window gave out, HELP !!!!
- what exhaust suits best?
- Center Cap over the Aisin Hub's
- 1990 V6 4Runner Head Gasket + Other Work
- starter not working when hot
- tow bar, need some intel
- 2nd gen coilover susp???
- 22R-E head replacement. Where does this bracket go?
- coolant everywhere, help please.
- 1500 miles in two days!!!!
- Relocated the license plate so visible with new MC bumper
- Help!!
- rear window pickup removal
- 3VZE Air Intake Chamber Not Sitting Flush
- Stupid me screwed something up with the idle
- is input noise common?
- Help deciding on clutch.
- I have a question about lifting up my 2WD automatic
- Minor Project Vent
- Need some tips for pullinga tranny
- 3VZE Knock Sensor Needed
- A340H xmission oil seal replacement
- Factory thermostat housing?
- Can i fit this engine in my yota.
- 93 overheating (yet another one)
- going to need to find a heater core
- MSD universal starters for the 3.0?
- ITS alive! 3.0 afm mod!
- 4-5" Lift Kit with shocks - Rough Country
- front and rear end gearing
- 3VZE Displacement Calcs
- AC Shakedown
- Oil leak! need HELP!!! A/C compressor?
- Need some help with vaccuum lines and couple connectors...
- 4runner picture request
- See my TOYOTA on Youtube
- How is this Bumper?? Warn Bumper
- Pic Request: Factory Front Gap Guard
- Anyone know what this Yota is?
- Pic Request!
- Common Oil Leaks?
- damnit (kinda off topic)
- bilstein 5100 vs. bilstein HD
- just out of curiosity...
- Battery, Intake Swap
- cold air intake
- Radiator fan has stopped kicking in
- Looking at 1986 4Runner
- 1990 Toyota Pickup runs sluggish in lower gears
- charcoal canister / vacuum issue
- Information About Radiators
- Brush guard and shocks...
- heater core rpm switch?
- Auto tranny kaput. What's it cost to do manual swap?
- 22RE Engine Light Question
- Air Control Valve?
- espana toyotas
- 1994 toyota pickup clutch line leak..
- Idling High
- No Reverse?
- Hard to start!
- BJ spacers and new springs
- help in vermont
- 1990 Truck Turns Over but Won't Start
- need new trans
- Looking at wheels in the future.
- I got questions about wat to do with my yota
- engine/tranny dropped in together?
- pics of newly installed 2" body lift
- Air Conditioning Install- Need direction please PICS
- Transmission pops hard out of reverse
- Need Help wirh some Body Work
- 1991 4runner cv joints
- strange problem
- Can someone please help me identify this part?
- 22RE from RT142 Corona to YN67 HiLux with 4Y?
- problem
- all pro front bumper
- 93 4Runner - washed engine, now it dies 3-5 sec after start
