radiator issues on 22re, sign of something bigger?
Old Jul 8, 2008 | 04:52 PM
skinnyhb's Avatar
the radiator on my truck recently started leaking significantly when i turn off the truck after a long drive. i pulled the radiator and the fins are easily broken if i push on them. i imagine that this is the reason i am leaking coolant, but should i take this perhaps as a sign of something more since the radiator doesn't leak under cold temperatures?
Old Jul 8, 2008 | 04:55 PM
abecedarian's Avatar
likely, it's no big deal... if you get the radiator replaced. the fins, and coolant tubes as well, are subject to corrosion and electrolysis (particularly since you're in Santa Barbara) and that sounds like what you're describing. when heated, things tend to expand so leaks become more apparent. Salt water spray is hard on copper and aluminum.
replace the radiator and see how it goes.
Old Jul 8, 2008 | 04:57 PM
TOYOTA 1's Avatar
^^^x2
Sleaker
Aug 26, 2020 06:03 AM
Sep 4, 2015 09:27 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
