weak blower motor
Old Jul 4, 2008 | 08:53 PM
nosecondz's Avatar
weak blower motor
hey guys my 86's blower motor barley hits my face on high, im in az and its super hot, ive replaced the motor itself and the new one blows as week as the old, is that normal or do you guys think my evaporator/or ducts are clogged.
any info or help would be great.
Old Jul 4, 2008 | 08:56 PM
ozziesironmanoffroad's Avatar
id say ducts
Old Jul 4, 2008 | 09:13 PM
pauliep13's Avatar
The ducts being clogged is possible. Might want to take apart the cover over the A/C controls and see if the cable is loose on the back of the lever. It might not be opening the flaps the right way to blow air out of the dash vents.
Also, are you the one who put in the last blower motor, or was it in there when you bought the truck, and do you know if the last one was even after market?
This happened to me, kind of embarrassing: Factory blower went out, went to Autozone for a replacement (mistake, I know, but it came with the lifetime warr.) Put that one in and used it for a year and a half, then it went out again. Went back to "tha zone" and cashed in on the lifetime warranty, and put that one in with crappy results. Air BARELY came out of the vents, much less hit my face. It was actually cooler in the truck while driving down the freeway from the air getting forced into the cowl vents. This led me to find out that on the wires on the second blower I received were: Blue = Negative and Black = Positive.
Never seen a simple electric device with a Black positive wire until that point, switched 'em around and it's worked fine ever since.
Just a thought.
Old Jul 5, 2008 | 05:41 AM
HAVOC's Avatar
Can you hear the fan noise increase as you go from low to high? You may have a bad resistor.
Old Jul 5, 2008 | 10:29 AM
toyminator2000's Avatar
x2 on the resister. I think I've had to replace it on every Toyota I've owned. If the speed doesnt change going from low to high then its your resistor.
Old Jul 5, 2008 | 10:41 AM
abecedarian's Avatar
I was going to say 'recharge the girlfriend' but then thought three times about it.
The resistor went out on my runner and I lost the first two speeds but had nice med-high and high speeds. So I'm guessing you're went out in reverse of mine- you have low speed but no high.
take a look here:
http://4crawler.com/4x4/CheapTricks/Blower.shtml
Old Jul 5, 2008 | 10:49 AM
TOYOTA 1's Avatar
isn't there a speed adjustment, like a Lil knob under the dash, passenger side??
it might be on low.
Old Jul 5, 2008 | 07:03 PM
ewong's Avatar
Mouse nest in the air intake in the COWL...
BTDT
Old Jul 6, 2008 | 09:50 AM
nosecondz's Avatar
it might be on low.
is there really a speed adjustment that sounds to easy. i'll check the ducts after i replace my comressor off coarse it had to crap out on me.
Old Jul 6, 2008 | 09:54 AM
TOYOTA 1's Avatar
im not shure, one of my friends said that there is one, passenger side under the dash.
okamikai
Apr 30, 2018 10:19 PM
PETDOC
Aug 18, 2015 05:29 AM
Flossy
Aug 5, 2015 05:14 PM
msane99
Jul 17, 2015 10:13 AM
