22re runs different after gasket replacement
Old Jul 6, 2008 | 10:20 AM
92yotapride's Avatar
Unhappy 22re runs different after gasket replacement
I need your expertise!! 92 p/u 4x4, 98k miles. Just replaced exhaust manifold gasket. Motor now idles low and rough. Also feels like lacking power and has slow acceleration. No vacuum lines disconnected. Could replacing the gasket have changed the timing. If so, what should it be set at optimally? john
Old Jul 6, 2008 | 10:23 AM
TOYOTA 1's Avatar
no that shouldnt change your timing.. maybe you knocked a plug wire loose by accident?..
Old Jul 6, 2008 | 10:27 AM
I checked the plug wires too. Someone told me to take the ground off of the battery for 5 minutes to reset the computer, that didn't do anything .
Old Jul 6, 2008 | 10:32 AM
TOYOTA 1's Avatar
hmmm. thats wierd, i dunno maybe a plugged muffler/cat?
Old Jul 6, 2008 | 11:51 AM
abecedarian's Avatar
It shouldn't have any effect on the ignition timing directly, but it could affect the idle speed because of other factors influenced by the exhaust and thus indirectly affect the timing due to those such as a change in backpressure and mixture readings by the O2 sensor. It wouldn't hurt to check the timing though. It should be set at 5 btdc with the engine diagnostic t1 and e1 terminals jumpered together. Also, the idle speed needs to be adjusted to where it's supposed to be, 750 with a stick, before you can get the timing set accurately. If getting the idle and timing dialed in don't change the idle quality, the egr valve could be suspect or as mentioned the cat could be plugged.
*edit- when you jumper the test connector, the engine speed should noticebly drop. if it doesn't the throttle position sensor may need adjusted as well: http://4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jul 6, 2008 | 01:46 PM
Thanks much, I'll check on that
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
puddlepirate
Jun 30, 2015 05:08 PM
serenity03k64
Jun 27, 2015 07:59 AM
scotts93
Jul 18, 2002 04:10 AM
