Int wiper motor needed for int wipers?
Old Jul 9, 2008 | 02:12 PM
Jay351's Avatar
A few months ago I noticed my wiper motor starting to make the familer sounds of a dying motor, so I picked up a used one from a 90 4runner. Fast foward to last week, in the rain my wipers are skipping and jumping, from what I have tracked down to the motor being to weak.
So I swap out my old motor (my truck has intermitted wipers, they work great), I put the new one in, get everything lined up.... and now I don't have intermitted wipers!!
So my question is, is there specific wiper motors for the intermitted/non intermitted trucks/4runners? I cant STAND having the old style wipers.
Old Jul 9, 2008 | 03:23 PM
anotherjeff's Avatar
Same motor. Maybe your problem is in the relay for the int wipers (passenger kickpanel above the ECU).
Old Jul 9, 2008 | 04:54 PM
Jay351's Avatar
Hmm, this is quite odd. Everything worked perfect before I removed the old motor and put the new one in.
Any other suggestions? Im this close to throwing the old motor back in to see if it makes a difference. Only takes about 15 mins anyways...
Old Jul 9, 2008 | 05:26 PM
JamesD's Avatar
Jay, on my 89 I swapped the steering column. Mine was originally non-tilt and non-intermittent wipers. The new one had tilt and intermittent wipers. All I did was bolt it up and plugged it in and I had intermittent wipers. The intermittent wiper module is already installed from Toyota. I do not know if your 91 is like that.
James
Old Jul 9, 2008 | 05:33 PM
Jay351's Avatar
Well, I assume the 89 and 91 are going to be very similar. I actually have been doing research as how to change my girlfriends non intermittent wipers to intermittent. From what I have read all you change is the switch in the steering colum.
But it makes no sence to why I now have non intermittet wipers. At the int setting they just go, like the next setting. The "fast" setting works fine though.
Im really confused....
Old Jul 9, 2008 | 05:41 PM
JamesD's Avatar
Sounds like to me you have a bad intermittent wiper module.
James
Old Jul 9, 2008 | 05:42 PM
Jay351's Avatar
Funny that it would go bad at that time... where is it located?
I will check the relay too.
Old Jul 9, 2008 | 05:56 PM
JamesD's Avatar
I don't know.
James
Old Jul 9, 2008 | 06:05 PM
Jay351's Avatar
Crap, well thanks anyways. I will look over my manual and the 93 FSM online. Hopfally sombody else can chime in..
Old Jul 10, 2008 | 01:29 PM
Jay351's Avatar
I tried them again today, and they work fine.... I have NO idea what that was all about.
Old Jul 11, 2008 | 08:47 AM
iamsuperbleeder's Avatar
...I actually have been doing research as how to change my girlfriends non intermittent wipers to intermittent. From what I have read all you change is the switch in the steering colum...
that's interseting; I may have to look into that
Old Jul 11, 2008 | 01:10 PM
Jay351's Avatar
Yeah, its kinda hard to get a sure answer on here with the silly search function. But after an hour I found out that you just need the switch itself.
I plan on pulling one out of a runner next time im at pick a part.
Old Mar 11, 2013 | 02:51 PM
anthony88us's Avatar
the module is located in the passenger side kick panel above the ecu as "anotherjeff" said
Old Mar 11, 2013 | 03:06 PM
rworegon's Avatar
Wow, after nearly 5 years another zombie thread comes back to life.........
What was the purpose of post #13?
Old Mar 11, 2013 | 03:08 PM
lol i didnt even notice the dates
Old Mar 11, 2013 | 03:19 PM
Co_94_PU's Avatar
YAPN..
If you swap motors and the intermitten wipers no longer work, it is likely one set of the windings is burnt out in your new motor. Inspection of the motor is covered in the manual. There is no module external to the switch in the 90's models, all the switching is in the motor or the switch in the column.
Old Mar 11, 2013 | 03:21 PM
so then if you were to swap a column that is fixed to a tilt column there would be nothing else to change or add?
Old Mar 11, 2013 | 03:50 PM
Co_94_PU's Avatar
Don't even need the column just the combi-switch assembly. You actually just need the wiper side but it's easiest to just move the whole assembly.
BigArt70
Jun 30, 2015 09:51 PM
cchinny
Jun 25, 2015 08:11 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
HALMAN
Jun 14, 2002 09:02 PM
