PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 [198] 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. It Runs!!
  2. Recent Mods!
  3. camo clad + bedliner
  4. Help needed
  5. Is this different or normal for stock gearing??
  6. 22RE Vacuum Lines
  7. Left passenger window goes down but not up
  8. Rear spring suggestions?
  9. front door speakers 4runner
  10. need help!
  11. A340H Temp Sensor Question
  12. 87 4Runner Sound Deadener and floor mat work
  13. sas anyone????
  14. Finally got the Bikini Top on! (I got for X-mas)
  15. Desperate need of help - rotor and shock replacement issues
  16. Electrical Help???
  17. removing complete ADD system?
  18. timing cover PO hack
  19. Hello, and question about my fan clutch
  20. rear axle prolem!!
  21. Monroe Gas-Matics
  22. adjusted tps, now odd stutter in rpms
  23. Message 14,24,25,31- 94 v6 4x4 pickup
  24. New to Yotatech, new truck, couple questions
  25. 22r emissions. What can go, what can stay?
  26. results from a day at hollister
  27. Leather Steering wheel wrap
  28. 22re head flow chart
  29. 91 Lifted 4Runner for sale in BC
  30. 86 pickup problem
  31. A/T Question?
  32. Bilstein shocks
  33. Battery draining, help please!
  34. 22R Headgasket???
  35. Locking hub help Asap
  36. subaru 2.5 boxer swap???
  37. Body lift with automatic transmission?
  38. Post you pics! Of your toyota pickups! Here is mine!
  39. 3.0 top end seals - help a noob!
  40. 22-re terrible chatter
  41. 22re Clutch Disc
  42. great 2nd gen in WA
  43. Not Starting...Any Ideas
  44. weird random motor tick
  45. Changed oil filter...runs way better
  46. Teflon Tape on Oil Sender?
  47. 1994 4Runner problem,,,
  48. Oak tree vs. 87 Yota bed
  49. acceleration vibration
  50. Questions about replacing a tranny
  51. Is it as simple as this?
  52. Auxiliary Fan won't shut off
  53. Starting issue (ignition??)
  54. 3.0 how bad is it really?
  55. Replace Head gasket or Replace engine block
  56. Rear Wndow - 87Runner
  57. KC Daylighter/HiLighter Mounts
  58. Stock ride hieght measurment
  59. Anyone neeed FSM for 1989 Truck?
  60. Tires for MPG
  61. bigblockyota
  62. Air Conditioning condenser fan
  63. THe best time.
  64. LC header install...
  65. swamper ltbs
  66. Basic High Quality Suspension
  67. 91 pickup 22re code 43
  68. codes 12, 14, 41
  69. Folks With Home Brewed Flatbeds
  70. Tire Preferences
  71. wtb: 93 left fender
  72. Trying to figure out gear ratio...
  73. Bought a 4runner *PICS*
  74. spare tire carrier bushing?
  75. 30"spare-225's all four
  76. Heavy Duty Torsion Bars???
  77. just sold that damn 4runner that i had!
  78. just sold that damn 4runner that i had!
  79. 3vz 1993 engine dead Did my timing jump?!??!
  80. SOS San Antonio Area! please help- Steering locked
  81. Would you trust your
  82. Whats the deal with the zip ties
  83. Engine cold, temp gauge shows overheating
  84. 34 x 9.5 on a 22re?
  85. horn, BIG, BIG, Loud sound.........
  86. one of those "noise" questions...thanks :)
  87. 3VZ, Cylinders .030 over
  88. Tune up Parts?
  89. Rough idle?
  90. My 93'
  91. Would like to see your 4runner
  92. Flowmaster 50-series
  93. Melted distributor cap and rotor
  94. Machine Shop in WA
  95. Brake pedal creep
  96. V8 MPG with 22re Power
  97. bent axle?
  98. Does this sound like a good deal?
  99. lubing my diffs and other chassis parts
  100. Running & Then Dying!!!
  101. Loud/sloppy sound in front end
  102. seat cover /pad
  103. Upper Tellico Rally Going On Now - Show Support
  104. If you fix a code will it stop coming up
  105. EGR what does this control, I have Code 71
  106. compression/leakdown test in Seattle
  107. had a chat with Tod Stanwood re:o/s valves
  108. 88 4runner buildup. awesomeness
  109. 88 4runner buildup. awesomeness
  110. master cylinder reservoir cap
  111. HELP!!! Burnt Valve issue
  112. Dying!!
  113. Pinch Weld and new 33x10.5 tsl's
  114. Would I regret buying these kinda kits?
  115. Its Awsome!!!!!!!!!!!!!
  116. '88 4Runner 4x4 v6 Starter Replacement?
  117. Need help with many problems
  118. HID lights?
  119. Clutchs / Pressure Plates - Discussion
  120. 4runner transformed
  121. 89 pickup 22re problems
  122. Front skid Plate
  123. truck trouble!!!
  124. E-brake cable
  125. Timing Chain Engnbldr VS. OE
  126. which flares are these?
  127. I'm buying a 1995 ext. cab Toyota pickup.
  128. i need an alternator plug
  129. 94 t100 steering question
  130. Not a broken CV axle seal... what could it be?
  131. distributor question
  132. 22rte vs. 22re timing cover
  133. Mounting 285/75s
  134. 1994 toyota 3.0
  135. Staring issue + others
  136. suspension lift
  137. Catastrophic coolant loss 95 4runner
  138. 86 22-RE idle problems!
  139. brake pedal
  140. New Member 94 2wd Xtracab Dlx 5spd
  141. Bearings and Spindle Bushings Bad----rebuild kit.
  142. Need Pics! 2nd Gen 4runner hitch vs 3rd gen I need pics of the hitch unmounted
  143. Hi-Lift + stock bumper
  144. uselss plug in dash
  145. 4.3 swap or rebuild 3slow
  146. Where do the other end of these power steering hoses go?
  147. The thing under my bumper..?
  148. How much Lift?
  149. Waterpump? Temp sensor? Nothing?
  150. Cail emissions and Federal emissions
  151. 1989 pickup with a 22R?
  152. Lift questions
  153. Part # Exhaust Stud repair Kit??
  154. has anyone ever seen a brown ext cab pickup?
  155. Help me read my engine codes with my You Tube Video
  156. Need help: Toyota mech's can't figure it out.
  157. Show Me Yall's 5" TrailGear Kit Pics
  158. Paint suggestions for Bumper/Grill
  159. Starter going bad?
  160. Anyone know if I can track an engine by its Serial#?
  161. intermittant starter issue?
  162. timing chain ?'s
  163. 94 Bucket seat compatibility question...
  164. 22RE idles at 750 but really badly
  165. Hard Brake Line Busted
  166. Throttle body question
  167. Tranny Help
  168. double shackle (pics please)
  169. power steering pump
  170. inclinometer and inverter finally installed!
  171. LCE Header
  172. White smoke...whats wrong?
  173. Strange rattle... or completly normal tranny/diff noise? Please give your 2-cents.
  174. Quick U-Bolt Question
  175. HELP valve question need answer ASAP!!
  176. Help me ID this hose
  177. New Engine Installed - Won't Start (22RE)
  178. Fuel pressure gauge on fuel rail?
  179. exhaust question
  180. Good question for you toyota guys!
  181. 1992 engine vs 1993 engine Temp Sensor Differences on back of intake???
  182. Changed spark plugs
  183. UUUMMM 22RE Fuel Filter
  184. Easy 4runner tailgate fix
  185. Broken injector pintle cap - symptoms?
  186. Need a dead computer and wiring harness
  187. Need quick response!!
  188. 85 4 runner- 3-5 lbs fuel pressure? WTF?
  189. Guess I don't have to worry...
  190. Question on airbox mod for 3.0...
  191. Replace L drive axle 94 4runner (w/pix)
  192. Persistent valve noise 22RE
  193. code 14 what is it?
  194. alternative cross over steering for sas
  195. Bad Fuel Tank Sending Unit
  196. NAPA ATM Brand
  197. 94 toyota pickup owners. Help
  198. Araaagghhh - Wire snapped off of sensor
  199. Please Help me Diagnose My Problems i have a You Tube Video to Help
  200. Doing headgaskets on a 94 3.0 v6 this is what i found.
  201. Well, I need a new wiring harness!!
  202. Well, I need a new wiring harness!!
  203. Do's and dont's on a '93 4Runner
  204. rims... will they fit
  205. 1994 pickup stereo wiring chart
  206. Any have a write up with pics to replace Oil Pan Seal
  207. Where is the plug to Read codes with The Code Reader
  208. DO you Drain Oil when Changing Oil Pressure Gauge
  209. New Dry Amsoil Aiir Filter with KN&N intake
  210. Does Cold Air Intake Give Better Milege
  211. Need help please!!!
  212. Need a real cupholder
  213. Should I buy it?
  214. Starter wires question
  215. hi-lift mounts
  216. OIL LEAK!!!! Heeellllppp!!!
  217. do i need a new intake manifold? broken bolt
  218. Replacing steering components
  219. Could it be the MAF sensor?
  220. Hydro-lock Aftermath
  221. snow pics and flex pics!! lets see yours!
  222. IS it worth it? spring & shackle bushings?
  223. For those who would like a locking glove box for 1st gen
  224. Need MAF circuit diagram or picture
  225. 99 4runner Rear Wheel Bearing Job
  226. 86 4Runner front heater is kaput
  227. 87 with a temper
  228. running rich??
  229. Roll over repair thread.
  230. mpg going up..... strange.
  231. Removing window crank
  232. new frame
  233. Need help with clicking in brakes
  234. pros and cons of 1991 land cruiser.
  235. 3.0 problem a/t temp battery oil light on
  236. Fuel cut rpm?
  237. Just got a '91 SR5 4x4
  238. Possible timing problem ?
  239. About to buy Thorley...fab necessary?
  240. Help diagonose the sound
  241. What to do with this truck? Lots of oil blowby on 22R
  242. Tips for Intake Removal
  243. Tranny fluid lines?
  244. Oil Question, with a twist.
  245. Someone please tell me that these wheels will fit!!!
  246. Coolant temp sensor failure
  247. Pics Finally!
  248. 22R gass mileage
  249. does code 53 = bad ecm?
  250. oil leak
