Engine cold, temp gauge shows overheating
Old May 8, 2008 | 01:26 PM
geoduke's Avatar
When I turn my truck on (v6 3zve) the temp gauge immediately jumps to the red position of the gauge. I figure it has to be some kind of bad signal coming from the sender or the way the gauge is reading it.
Does anyone have any ideas? Most of the threads I see have to do with actual overheating problems or trucks reading cold all the time. If the temp sender is bad would it read always hot or always cold?
Old May 8, 2008 | 01:57 PM
hross14's Avatar
Three areas i would check out
1. Is the senor good
2. Is the gauge working correctly
3. Isolate the temp sending unit wire and see whether or not it is grounding out.
Number 3 i have seen happen a couple times--except it was a jeep
bigjstang
Jun 2, 2025 03:56 PM
BushPig
Oct 29, 2022 06:26 AM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
ptb12
Jul 5, 2015 01:49 PM
