rims... will they fit
Old 05-03-2008, 08:16 AM
Toyotero's Avatar
Would stock rims from a full size Chevy pickup fit a 1986 4Runner? I'm uncertain about bolt pattern size and off-set...
I'm shopping for a set of wheeling tires, and there are always a few deals on 33X12.5X16 ATs and MTs on Chevy rims like these:
Old 05-03-2008, 08:32 AM
iamsuperbleeder's Avatar
Assuming the pictures on the top left are from your Toy and the other ones are from the Chev, then no way. Your Toy wheels are 6 lug and those Chev ones are 8. But I do have a set up 33/12.5 Boggers that I hardly ever use that I pulled from a full size Chev that was 6 lug. The bolt pattern is an exact match, but they stick out crazy far because of how far the rim is off-set.
Old 05-03-2008, 08:43 AM
Jay351's Avatar
If you happen to buy a set of stock 6 bolt chevy wheels you will have to bore out the center hole by about .5" to fit.
Old 05-03-2008, 08:49 AM
good point on that too
Old 05-04-2008, 08:32 PM
Toyotero's Avatar
Actually those are both Craigslist ad photos... I completely overlooked that the MT rims are 8 lugs (ooops!)..
Old 05-04-2008, 08:33 PM
Toyotero's Avatar
Thanks, that's exactly the kind of info I was wanting.
Old 05-04-2008, 08:47 PM
...the kind of advice that only experience will bring out, lol
I didn't have the issue because the Boggers were mounted on aftermarket wheels N E way
Old 05-04-2008, 08:59 PM
4Crawler's Avatar
Yes, this is the case with some Chevy rims. You need about 4-1/8" center bore to clear the front hubs on the Toyota (you can always measure your front hub OD to make confirm the dimension). So just check the ID of the center hole on the rims to make sure they will clear the hubs on your truck.
87SR5justin
09-29-2015 02:50 PM
4runnerFireman
09-29-2015 06:24 AM
myotherrideisayoshi
09-29-2015 05:41 AM
mtrdrms
09-26-2015 07:12 AM
anniesball
09-05-2015 08:45 AM
Quick Reply: rims... will they fit
