'88 4Runner 4x4 v6 Starter Replacement?
Old May 6, 2008 | 10:54 PM
B-b0y's Avatar
Hey guys, bought my starter today and wanna get it swapped out tomorrow. Does anyone have a Do It Yourself link with all the tools I'll need and easiest way to replace it? I did a search but can't find anything for an '88. Any help would be GREATLY appreciated. Cheers...
Old May 6, 2008 | 11:28 PM
nv4runner's Avatar
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Not sure on the tools but it should be pretty easy. I've got a 92 4runner, so this may not apply to you (depends on 1st gen or 2nd), with a removable panel that is bolted on above the upper control arm of the passenger side wheel well. This gives you easier access to the starter. Removing the wheel also helps.
Luckily I haven't had to replace or even remove my starter. I just did some tests on it for class and found out that the starter control circuit on these is a very efficient design with very little voltage drop.
Old May 7, 2008 | 02:54 AM
redheaded step truck's Avatar
14 mm 12 mm 10mm and some fussing & cussing
this should be all u need
Old May 7, 2008 | 05:49 PM
mtnfreak's Avatar
Try these links (same thing, different look):
https://www.yotatech.com/forums/f128...4runner-76358/
https://www.yotatech.com/~corey/tech...imrockford.htm
mskalmus
May 28, 2017 07:51 AM
izzmee
Aug 17, 2015 10:20 AM
Dakotaneu
Aug 15, 2015 07:24 AM
rustym
Aug 7, 2015 10:39 AM
defrag4
Jul 31, 2015 10:50 AM
