PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 [249] 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. CEL code 71 on a non-cali vehicle...
  2. Weight of my Yota...??...
  3. 94 3.0 won't start
  4. Lifter noise?
  5. Tailgate window question ---easy one
  6. How much can I get for 4 stock rims off a 88 toy 4X4?
  7. 3rd Memb. Leak?
  8. Clicking sound when wipers are on?
  9. POST YOUR PICS FOR 95 RUNNER / Comments
  10. Runner starts and then stops
  11. knock sensor question
  12. same 22-re...new codes
  13. arb winch bumper questions
  14. newb Tire size question, 225s or 31s stock?
  15. low idle on cold start
  16. need new shocks for 95 runner with 4 inch lift?
  17. 95 runner RECALL
  18. ECU differences??
  19. Any 4runner clubs in NY?
  20. Rolled my truck
  21. Bad smell when the HVAC is blowing.
  22. 22re only getting16mpg
  23. 4Runner Condenser Placement
  24. Truck Wont Start On First Try
  25. Gas prices around your neck of the woods?
  26. Help Asap!!!
  27. Timing Cover Seal Question (22re)
  28. Defrost = more fog? What's wrong?
  29. update on 86 rebuild.
  30. 92 22re tmiming issues
  31. 92 22re tmiming issues
  32. I now own the Legend.
  33. Do you still have the original fuel filter on your 3.0?
  34. First time Toyota 0wner with questions re oil, tires, etc
  35. THIS turbo + 3vz-e = FUN!!
  36. Removing rear view mirror - how?
  37. Odd intermitent noise
  38. Should I buy this 1995 4 Runner
  39. Loud "CLUNK" when turning at full lock...ideas?
  40. tires and water problems
  41. $1000 to fix hiem joints
  42. Won't Start ...
  43. LT1/LS1 swap (fuel injection)? Anyone completed this?
  44. Clutches
  45. 86 Toyota 4runner
  46. Clutch MC leak, why?
  47. Idler Arm Rebuild?
  48. Transmission Leak
  49. Timing cover gaskets
  50. 32x11.5x15 Cooper's/Mtr's
  51. Axle Width Help
  52. New Aussie Locker in Front
  53. BILSTIEN 5100 series shocks
  54. Move to 3rd gen or stick with my 2nd?
  55. where to get bolts for 5vzfe?
  56. Transmission Leak
  57. Bad Vibration
  58. There's this runner for 400....but has an electrical problem
  59. Ball Joint replacement.
  60. A/C compressor voltage #'s
  61. how do I install chrome window moulding????
  62. Bed Price
  63. Best Head Gasket? -3.0 V6
  64. 22RE Fuel Injectory Compatibility?
  65. ENGNBLDR CAM's
  66. blew a head gasket last night
  67. Wiring harness Q
  68. What gears do i have?
  69. Engine show some eating metal
  70. 88 4 Runner - Clutch Help / Advice
  71. My rear main seal is done for
  72. Replacing head gasket
  73. 3vze surge/power loss, code 25, 26
  74. clutch fan may be going out?
  75. 22RE 2WD average fuel economy and can it be improved?
  76. Braking problem!?
  77. Once again Exhaust Troubles!
  78. 4x4 light?
  79. Need some tire advice
  80. 1987 4runner stalling and does not idle
  81. Best aftermarket fenders
  82. Gen II rims and tires --> worth cash?
  83. What battery for a truck that sits too much?
  84. MPH off after adding tires ???
  85. new alternator - battery/brake light on!
  86. head gasket took a poop
  87. Personal Plates-Voting
  88. A few questions dealing with my 94 pickup.
  89. How will an add-a-leaf affect my sagging rear?
  90. Price My Runner
  91. 96 3.4 swap into 90 4Runner q's. S/C?
  92. Timing chain successfully replaced
  93. What's the proper way to tap a wire?
  94. Thinking of 32's
  95. Rear sag - 89 4Runner
  96. Need a little wiring advice
  97. timing cover
  98. Flex-a-Lite bolt on fan
  99. Fuel pressure tester?
  100. Really BAD Pinging, but timing is ok?
  101. Timing Belt Installed Wrong?
  102. front brake problems.
  103. What to take the power from?
  104. driveshaft play question
  105. Ignition Cylinder
  106. 3 hours wrestling with CV joint, please help
  107. cam sproket
  108. Fuel Gauge Problems
  109. see a nice old tired 22rtec
  110. Fuel system problem- 4 runner wont start
  111. 89' Tps
  112. Trying to find the oil leak...
  113. Reverse glow gauges installed! (pics)
  114. Toyota truck 22re shakes and blows smokes
  115. can i rtv between intake plenum and intake on my 3.0
  116. Performance Intake Question??
  117. Quick lock, lunchbox locker any good???
  118. Options for a new radiator?
  119. Pepper in the radiator? What the.......
  120. yota tec rocks pulling motor
  121. Tapping Sound After Newly Finished Top End
  122. Code checking
  123. Annoying Brake Pedal Squeal - Please Help if You Can
  124. Rear Diff seal part # question
  125. looking for the front e-brake cable
  126. Timing chain guide question
  127. Missing badge?
  128. Question about some SR5 15x7 wheels with different offsets
  129. 3.4L swap q? on bolts
  130. Dirty injector(s?) Bad O2?
  131. Two Torn CV boots
  132. Looking to get rid of the rear end "sag"
  133. Body parts interchangeability
  134. What type of Gas do you use?
  135. A quick tie rod question
  136. The latest in 22RE bolt-on Goodies....
  137. Tranny cooler problems
  138. Brackets
  139. Not upshifting cold
  140. 3vze water pumps. cast or stamped impeller?
  141. 3VZE bad luck
  142. ABS help needed...
  143. 3vze Motor Questions..Poss Motor Swap!?!?
  144. how to have a spare 31" tire with tow receiver/hitch?
  145. Help Identify Clunking Noise
  146. Air box?
  147. Mods on a strict budget! Cheap tricks needed.
  148. Having trouble starting on warm starts
  149. Miss at idle
  150. Power Antenna repair or replace with fixed?
  151. Hella 500 wiring clarification (searched)
  152. Check engine light- code 25 and 26 3VZ-E
  153. Rear Speakers? Not Working?
  154. I need some help hooking up my tach
  155. Converting TO Electric Door Locks
  156. oil pan gasket ?
  157. does an 87 dashboard fit into an 88?
  158. Code 71
  159. Control Arm Bushing replacement?
  160. Knock Sensor Questions
  161. 1990 pickup carb problem
  162. Which pressure plate to purchase?
  163. Superwinch Hubs
  164. Knocking when accelerating, what could it be?
  165. Exhaust Recommendations?
  166. Front Mount Hitch?
  167. 22re computer question
  168. New clutch - Boulder area?
  169. Need some Quality Shocks for a 2wd PU.
  170. Yotatech rocks!!! but this is an engine swap question
  171. Shift plate for a 94 std. and Idler arm question
  172. bent frame
  173. New Engine, Rough/Dieing Idle + Hot Pleneum
  174. Dead gauges due to fuse box
  175. 91 22RE questions
  176. downy rear coils or cruzer coils?
  177. '92 4Runner 4X4 problems
  178. 3.0 Throttle body coolant bypass
  179. 22R burnt valve or something else?
  180. Recall on a 94 toyota 4x4?
  181. My Rusted 4runner - Should I save it?
  182. intake & exhaust valves
  183. Brake Upgrade, need opinions
  184. help with oil leak
  185. Cant wait for my clutch
  186. Which Recall is this?
  187. Two Braking Problems!
  188. 88 4runner doors hinges needed
  189. 91 4x4 axle
  190. curious about headers for 3.0 V6
  191. passenger side power window problem
  192. Grill swap?
  193. Running rough/miss?
  194. High speed braking vibration
  195. tires??
  196. Body Swap 4runner to pickup
  197. Exhaust Manifold & Piping ?
  198. How much does it cost to rebuild a carb for a 4cyl 1987?
  199. rear leveling??
  200. check eng.lite on,but no codes
  201. High mileage valve adjustment
  202. 22re stuck to tranny
  203. Hole in new ball joint boot
  204. Need Pictures of Engine Bay
  205. Bad Gas Milage??
  206. Lets make a list of good technical websites
  207. I think i'm having tranny problems
  208. Flowmaster part # for a 91 2wd pickup?
  209. Yet another reason to pull that luggage rack off
  210. 3.0 What do you think?
  211. Mustang wheels on a 2wd 91 pickup?!
  212. YotaTech rocks Just did the lspv mod
  213. alarm/remote start question
  214. Head Gasket
  215. '94 Headgasket, Tune-up & Bushing questions
  216. Engbldr Steel Rail Warning!!!
  217. Starter Solenoid Insulating pad Part Number
  218. 95 4runner 340F valve body detailed manual
  219. roof mounted light bar and daylighter q's
  220. 3.0 MOD Differences - what did you do and what did you notice?
  221. Cylinder Head
  222. Guage pods....anyone have one of these??
  223. 1994 Truck Rear leaf spring help!!
  224. wont start maybe timing?
  225. 3.4 swap with 3.0 motor mounts.
  226. Random Surge/Chug/Power Loss?
  227. Backspacing on stock 15x6 wheels
  228. drain plug on tranny
  229. Wiring for 95 3.0 auto
  230. A fresh 22RE, AHHH THE FUN! LOL!
  231. top moldings of windshield
  232. help with trans
  233. anyone adapted a ct-26 turbo to fit their 22re-t
  234. Gen II 4Runner and front calibers
  235. Gen II 4Runner and LPV
  236. Shocks/Springs????
  237. looking for fiber glass front fenders
  238. 94 4runner vacum hose questions
  239. Blower motor resistor GONE?
  240. Valve lash for EB 268 cam?
  241. 89 IFS Power Steering Gear sector shaft Seal
  242. got a 4runner
  243. synth oil offer
  244. Everyones favorite, on a spool decision!
  245. 22Re low compression ? please help
  246. Freaking Ball Joints!
  247. Lookin for a Pic. (plenum line)
  248. Any difference between 90-93 shackles and 94-95?
  249. fixed things and still the low idle
  250. Coolant Leak from Passenger Side Block
