roof mounted light bar and daylighter q's
Old Sep 9, 2006 | 11:05 PM
neilan's Avatar
ok i have a 1st gen 4 runner. I am wanting to put 4 daylighters up on my cab but am not satisfied with any way i have thoguht of to mount them. I am considering bendign up my own lightbar but really have no clue how i would attach it to the roof. I am hesitant to put any holes into my roof. unless i know it will work and not have problems. ANyone have any ides for a good 1st gen lightbar? and how i can mount it up there. My fab skills are good and i cna bend wweld cut whatever but its the ides department i am lacking.
Next i have questiosn about the actual daylighters to mount there. I was considering kc daylighters that are 100wat quartz halogen bulbs but came across these summit racing brand daylighters
http://store.summitracing.com/partde...5&autoview=sku
as for the specs they all seem to be the exactly the same and i might even be able to replace bulbs with with kc ones if they ever die. As for parts, them come with a dual lighted rocker switch and wiring harness but no relays. I am liking these lights because they seem decent i have a 20 dallor cupons and they woudl cost half as much as kc's. Anyone got some opinions? Also do i need to run a realy for each light? and what relays should i use if i was to get these?
Old Sep 10, 2006 | 10:05 AM
neilan's Avatar
help...anyone...
Old Sep 10, 2006 | 12:35 PM
Sonofmayhem's Avatar
go with a gutter mount as in where it mounts to the gutters above the door, you will have to drill and put in either rivets or self tapping screws , since its just holding lights. i personally dont like those daylighters, im gonna get the hella driving lights and put those on my rack, when i get it.
Old Sep 10, 2006 | 12:36 PM
95RunnerSR5's Avatar
fab up one that fits into your factory roof rack
Old Sep 10, 2006 | 08:51 PM
neilan's Avatar
haha ist gen doesnt have a factory roof rack.
Old Sep 10, 2006 | 09:11 PM
Yota Runner's Avatar
if your insistant upon fabing your own light bar then the drip rail attachment would be a good solution. I had a steel horse light bar on my 86 yota pickup and it worked and looked great (about $80 I believe) it attached to the drip rail, you could also look that up and get some ideas as to how they attached theres. As for the lights I am no guru but I think you would only need 1 relay for the set of four lights, someone correct me if I am wrong. You can get a relay just about anywhere.
Old Sep 10, 2006 | 10:04 PM
neilan's Avatar
ya i a m pprettu sure that i need at least 2 relays. haha as for the lights they may have to wait because i found an good deal on a 81 pickup that i cnat resist buying and it will be suckign all of my spare time and cash for the next year
Old Oct 15, 2006 | 03:44 PM
BigWavePaul's Avatar
Thumbs up KC makes one, found on www.Froogle.com
Here's a bomb-a** lightbar that I plan on putting on my 94 p/u. I didn't want to put in a rollbar because I come from a contruction trade background and anything that would take away from the space in my bed is out of the question. See here: http://performance.drivewire.com/getparts/index.aspx?pdef=Light%20Bar|Toyota|PICKUP|1994|DLX |||||Lighting
Old Oct 15, 2006 | 07:08 PM
Greg_Canada's Avatar
I have a stealth light bar, same as this one, nice and clean.. sunroof will still open as well!
Old Oct 22, 2006 | 04:48 PM
SKNKWRX's Avatar
I have the KC gutter mount bar (I found it in my friends garage this summer) with 6 lights. couldnt find the clips for the gutter so i fabricated some from a set of yakima gutter clips from a roof rack, worked perfectly. next is finding a flush mount female to female plug of some sort to put in the fiberglass topper so i can easily unplug and remove the bar or the top, I run a black can-back top in the summer.
Old Oct 23, 2006 | 08:05 AM
trd90toyota's Avatar
4Pin trailer harnes. I have one hooked up to mine so when I want to remore the top. Works great.
Old Oct 23, 2006 | 09:29 AM
SKNKWRX's Avatar
Im looking for something more industrial thats flush and has a cap to cover it when i remove the light bar. There are some applications on this site http://www.deutschipd.com/Products/products.htm that seem to be heading the direction I want.
Old Oct 23, 2006 | 10:28 AM
lofreqjeff's Avatar
This is the light bar I have for my 1st gen
http://www.carr.com/store/carrdeluxerota.asp
Sep 4, 2015 09:27 AM
Scotto6591
Sep 1, 2015 03:24 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
