Braking problem!?
Old Sep 18, 2006 | 05:22 PM
94toyota4x4's Avatar
Thumbs down Braking problem!?
This gets really annoying, when I go to brake some what hard it swerve to the right, it used to do it to the right now its the left, I bled both brakes like crazy could it be alignment? help!
Old Sep 18, 2006 | 05:25 PM
Saint_Berzerker's Avatar
Yeah, either alignment or balance. That's what it probably is, unless you just have an extremely unusual problem.
Old Sep 18, 2006 | 06:09 PM
GSGALLANT's Avatar
Calipers need to be rebuilt? How easily do all the pistons move in and out when you try to move them?
Old Sep 18, 2006 | 06:47 PM
yota_krazy's Avatar
calipers x2.
Old Sep 18, 2006 | 07:31 PM
I didn't think calipers because he said that it used to pull one way, now it pulls the other way...so.....
Unless one fixed itself, or the other caliper got twice as bad as the original bad one??? lol
Old Sep 18, 2006 | 07:39 PM
Bazooka_cow's Avatar
i would check these first definatly. it sounds more like you alignment than anything.
Old Sep 18, 2006 | 08:12 PM
Well Im going to take it in to the toyota dealer for the recall and I guess they do a free alignment so I let you guys know if thats it, but the pistons on the driver side where kinda hard to push when bleeding, how easily should I be able to push them?
Old Sep 18, 2006 | 08:15 PM
jeepboyny's Avatar
I'm pulling hard to the left. I have a new caliper on the left side. I took the right off last night, and it looks like the 2 outside pistons are working, and the 2 inside ones are frozen. I can put a piece of cardboard between the brake pad and the rotor.. Time to give autozone another $40 I guess!!
Definitely check the calipers to see that all 4 pistons are moving freely. if you're lucky enough to be able to get them all out without damaging them, a rebuild kit is only like $4-5
Old Sep 19, 2006 | 05:26 PM
HOw can you tell if its frozen, if they dont move at all or if they are really hard to move?
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
