I think i'm having tranny problems
Old Sep 10, 2006 | 05:02 PM
AzGreg 01's Avatar
I have a 1995 4runner and I am having a problem with the a340f tranny I think ! it will only drive in 4 wheel low i can go in to 1, 2, and drive . i droped the pan and the fluid did not smell burnt and there was not really any metal shavings and no chunks. So i drained it again and removed the valve body and one of the pistions fell out when i removed the valve body could that be the problem? the valve cause the other two stayed up in there? thanks
Old Sep 11, 2006 | 05:53 PM
AzGreg 01's Avatar
you lames no one has any help for
i've posted twice about my tranny problems and had serveral views and no has any comments
Old Sep 11, 2006 | 06:04 PM
Dublin's Avatar
Is the 4WD disengaging? The light on? Have you checked linkages? Seems like somthing broke or came apart linkage wise. Not sure of what to make of the piston falling out of the valve body, but it seems the tranny was shifting but not the 4WD.
Old Sep 11, 2006 | 09:03 PM
MMA_Alex's Avatar
youre saying it only drives in 4low? What type of t-case is it?
Old Sep 16, 2006 | 01:53 PM
AzGreg 01's Avatar
Tranny or transfer case?
It slips in every thing other then 4 low the i can shift in reverse 1st 2nd and drive but other then that shes busted
Dieselmann
Feb 19, 2019 02:57 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
