Two Braking Problems!
Old Sep 11, 2006 | 04:40 PM
94toyota4x4's Avatar
Exclamation Two Braking Problems!
Ok, When I go to brake hard the truck wants to go to the right real bad so I have to fight it, I just took the caliper off a few days ago to do a cv boot service, I bleed it and it still brakes to the right, o yea, I bleed the driver side if that helps any, could it be alignment, second question, when I go to apply pressure on the pedal it starts to brake gently then when I get to a certain point the brakes grab real hard it gets real annoying sometimes, if anyone could tell me how to do allignment also that would be great, its a 94 toyota pickup 22re, if that info is needed, any adive would help, thanks.
Old Sep 11, 2006 | 05:11 PM
Elton's Avatar
well your first problem is a seized caliper
Old Sep 11, 2006 | 05:42 PM
Firefightertaco's Avatar
sound like your second problem could be due to the sticking caliper too, when your push the brakes hard enough that caliper might come unstuck and lock donw on that rotor. try cleanin the caliper and then bleed all the brakes
Old Sep 11, 2006 | 06:34 PM
isaac338's Avatar
or a kinked brake line on the left side, not allowing pressure to the caliper. check the soft hoses especially.
Old Sep 11, 2006 | 08:09 PM
Thanks for the tips, I'm definetly going to try it this weekend, but know that I think about it when I was taking the caliper off I acciedently drop it and it kinked the main metal tubing a little, Im going to see if I can look up the driver side on dirt, keep that advice comin, do you guys know anyhting about alignment?
Old Sep 11, 2006 | 08:12 PM
86SR522REEFI's Avatar
aligments are best left to shops with the equipment. There is a thread around here somewhere. use the search up top to find it.
Old Sep 11, 2006 | 08:21 PM
Alright thanks.
Old Sep 11, 2006 | 09:45 PM
CyMoN's Avatar
i have found it is best after doing the calipers is to take the truck on a gravel road less stress on the tires and gives a vibration and lets one brake stop while the truck can still travle a few more feet for the other to catch.
at least it has worked for me.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
skoti89
Sep 11, 2015 07:46 AM
Johntom240
7
Jul 13, 2015 12:18 AM
Jnkml
Jul 6, 2015 01:20 PM
